Drive Stops?
Old 08-14-2007 | 06:40 AM
fastedy's Avatar
Default Drive Stops?
Is there such a thing as a drive stop, maybe somthing that would sleave onto the trim rods to stop it from comming in all the way. I would like to put a stop on the drive to so it will not
tuck in below level, does this make sence?
Eddie
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 08-14-2007 | 07:42 AM
I have seen them on tabs. Fountain made and installed them on many boats years ago. It was a split donut like piece that was bolted together and made of nylon or delran.
Don't you need the tuck to get on plane?
Jim
MOBILEMERCMAN is offline
Old 08-14-2007 | 01:55 PM
Bilgerat's Avatar
there are different bolts that can be used internal the trim rams to limit the "in" tuck, also small "c" shaped pieces that will limit the out or trailer position, to keep from smashing a platform
Bilgerat is offline
Old 08-15-2007 | 08:58 AM
fastedy's Avatar
Jim
Thanks, thats what I thinking about, get's on plane just fine at level.
Mario Andretti
fastedy is offline
offthefront
5
03-23-2008 04:01 AM
fastedy
Drives and Lower Units
0
08-11-2007 06:57 AM
tomcat
15
10-29-2002 07:35 PM
