Racing engines...what breaks most often?
Just curious for those with racing engines or who race...is there a component of the engine that breaks more often than others? From what I have seen and read, it seems the bottom end of these engines is usually pretty robust, rarely failing? If so, then would that mean valves/springs/cams would be the leader?
Baja 252 Islander
Baja 252 Islander
You guys are too funny…but you are all correct… bajaman having raced supercat for a few years and being
directly involved in engine development, the valvetrain / camshaft are the biggest hurdles in racing that class. Things we’ve done included 55 mm roller cam bearings , truing up lifter bores. Bigger diameter lifters, various ramp designs on camshafts, using tool steel
camshafts, valvespring pressures , made own in-house rockers, used various retainers/ locks . The biggest helpful change was when we lowered the RPM to 7000 it helped stabilized it Speeds went down aiding in the safety of it. At the time I felt canopy construction was still lacking. Still loved the sound of the big block screaming at 7600 rpm kinda missed that.
