Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
Extreme Typhoon, poised for takeoff >
Old 04-09-2004 | 10:09 AM
  #81
Ron P's Avatar
Enjoy the show
Keep the reports and photos coming.
Ron P is offline
Old 04-09-2004 | 05:04 PM
  #82
FRIENDSHIP 1's Avatar
Randy,
Best of luck with the beast... See ya soon.
FRIENDSHIP 1 is offline
Old 04-09-2004 | 06:18 PM
  #83
TYPHOON's Avatar
After further reports I heard numbers in the high 80's in calm water. Rough water was a differant story. It needs to be balanced and set up better.
MD
TYPHOON is offline
Old 04-09-2004 | 09:22 PM
  #84
Phantom1's Avatar
The center of gravity has to be an issue. Remember, Rick ran a #5 with a custom Stainless Marine jack plate/extension box. If you never saw it.......it would blow you away. Lots of weight on the transom though compared to now.
I have no doubts that they will get the cg shifted and work it out for the lighter drive set-up.
Phantom1 is offline
Old 04-13-2004 | 12:45 PM
  #85
Hi-Tech Marine's Avatar
Once close... I like to run a remote fill/discharge water ballast tank up in the bow... you can fine tune the balance under way to water conditions and as they change.
A 20 or 25 Gallon tank should do it.
Again, GREAT job on the boat!!!!
Hi-Tech Marine is offline
Old 04-13-2004 | 02:49 PM
  #86
TYPHOON's Avatar
Bill the boat has a balast tank in it. Changed a few things and seemed to level it out better.
MD
TYPHOON is offline
Wodster69
07-02-2008 02:37 PM
Michelle May-Schmidt
11-04-2002 12:59 PM
