Grand Haven, MI exhaust...
#41
I agree on taking away from the looks. The PVC looks like crap hanging off expensive boats. I think people just don't wan't to spend any money. Gibson makes the 90deg. stainless polished turn downs for under $500. At least those look nice.
#42
In doing some more research, I was unable to find the 90dB noise ordinance listed anywhere on Grand Haven or Ottawa County's web sites, but CORSA's web site did indicate that Michgan has a 90dB limit, measured to SAE-J2005 standards:
"The noise emission test measurements shall be made with the sound level meter at a distance of at least 4 feet above the water at a point where the transom gunwale and port or starboard gunwale intersects. The vessel being tested shall operate its engine at low throttle setting in neutral gear."
In my case, I would agree that the meter was 4' above the water, but it was also in the center of the transom, about 1' back right in line with the center mufflers. I don't know how much difference it would have made 1' forward and at the corner, but it sure as he!! worked to my disadvantage.
Bottom line: If the law is on Michigan's books, it will be hard to fight providing the test is properly administered. The better suggestion may be to apply more leniancy to first-time offenders (and out-of-towners!), and to allow operation in any mode that meets the limits, whether it be Captain's Call or single-engine idling. After all, the point is to keep the noise down, isn't it? Why should anyone care how it's done, as long is it meets the requirements?
Any proposals from the condo owners as to how to quiet down the trains or ship's horns????
Cut and pasted from MCL law library
6.10 Equipment Requirements and Required Personal
Flotation Devices
A. Misdemeanor—Equipment Requirements
MCL 324.80156 details the sound requirements for motorboat mufflers and underwater exhaust systems. MCL 324.80156(1) states:
*MCL 324.80156(2) allows the DNR to establish rules for alternative sound level tests and maximum decibel levels.
“Subject to subsection (2),* a person shall not operate a motorboat on the waters of this state unless the motorboat is equipped and maintained with an effective muffler or underwater exhaust system that does not produce sound levels in excess of 90 dB(A) when subjected to a stationary sound level test as prescribed by SAE J2005 or a sound level in excess of 75 dB(A) when subjected to a shoreline sound level measurement procedure as described by SAE J1970. The operator of a motorboat shall present the motorboat for a sound level test as prescribed by SAE J2005 upon the request of a peace officer. If a motorboat is equipped with more than 1 motor or engine, the test shall be performed with all motors or engines operating. To determine whether a person is violating this subsection, a peace officer may measure sound levels pursuant to procedures prescribed in SAE J1970, issued 1991-92.” A person who violates MCL 324.80156(1) is guilty of a misdemeanor punishable by: • imprisonment for not more than 90 days; and • fine of not less than $100.00 or more than $500.00. MCL 324.80156(6). In addition, the person must install a muffler or underwater exhaust system that meets the act’s requirements before putting the vessel back in use. Id.
R 281.1238 Mufflers; cut outs.
The exhaust of all internal combustion engines used on any waters of this state shall be muffled effectively by equipment so constructed and used as to muffle the noise of the exhaust of the engine in a reasonable manner. The use of cut outs, bypasses, or similar devices is prohibited, except for vessels competing in a boat race or regatta sanctioned by the department under sections 151 and 152 of the act. A modern device, underwater exhaust system or a system discharging cold water through the exhaust of an inboard engine, each of which is capable of muffling the noise of the exhaust of the engine in a reasonable manner, shall be considered as meeting the requirements of this rule.
#43
Here is the procedure.
Excerpt from SAE J2005
(copied and pasted from pdf)
4. Procedure
4.1 Measurement Site—A suitable site is a body of water free of large obstructions or reflective surfaces such as
buildings, boats other than those involved in this procedure, large embankments or breakwaters, etc. for a
minimum distance of 8 m (25 ft) from the boat being measured. The boat being tested shall either be moored
to a dock or lashed to another boat. If moored to a dock, the dock shall be of open construction so that it
presents a minimum of reflecting surfaces. If the measurement is made in open water, the boat being
evaluated shall be lashed to the measurement boat to prevent relative motion and to allow positioning of the
microphone in the prescribed location. The measurement boat shall be positioned to minimize reflected
sound.
4.2 Boat Operation—The engine shall be operated at low idle speed within the engine manufacturer's
recommended operating range, in neutral gear if so equipped. For motorboats without a neutral gear, the
engine shall be operated at its lowest operational speed. The engine shall be operated for a sufficient amount
of time to allow water to flow through the exhaust system before taking measurements.
4.3 Measurements
4.3.1 The microphone shall be placed at a distance of 1.2 to 1.5 m (4 to 5 ft) above the water and no closer than
1m (3.3 ft) from the vertical projection of any part of the boat in the area adjacent to the exhaust outlet(s).
4.3.2 The meter shall be set for slow response and the A-weighting network.
4.3.3 The observer reading the meter shall not be closer than arm's length from the microphone to minimize sound
reflections.
4.3.4 The applicable reading shall be the average sound level measured during a period when the background
sound level is at least 10 dB lower than the measured sound level. Background sound level includes wind effects, noise from boats other than the one being measured, wave action, boat wakes, and other extraneous
noises.
Peak readings of intermittent sound levels created by wave slaps or changes in sound level due to
wave action and/or engine speed variation shall not be included in the applicable reading.
4.3.5 The observer shall record the applicable reading and the background sound levels taken immediately before
and immediately after the applicable reading.
5. General Requirements
5.1 The measurements shall be conducted only by persons qualified by training to perform these measurements.
5.2 Proper use of all test instrumentation is essential to obtain valid measurements. Operating manuals or other
literature furnished by the instrument manufacturer should be consulted for both recommended operation of
the instrument, and precautions to be observed.
5.3 Proper acoustical calibration shall comprise the complete measurement system including extension cables,
etc. Field calibration shall be performed immediately before and after each test sequence.
5.4 A measurement shall be invalid if changes in the background sound level affect the applicable reading.
5.5 The use of the word "shall" in the procedure is to be understood to be mandatory, while the word "should" is to
be understood as advisory.
PREPARED BY THE SAE MARINE SOUND LEVEL SUBCOMMITTEE OF THE SAE MARINE TECHNICAL COMMITTEE AND THE SAE SPECIALIZED VEHICLE AND EQUIPMENT SOUND LEVEL COMMITTEE
4. Procedure
sound.
4.3 Measurements
reflections.
noises.
#44
If you are really into reading, here is J1970.
J1970
ISSUED
DEC91
1991-12 Issued
400 Commonwealth Drive, Warrendale, PA 15096-0001
SURFACE
VEHICLE
RECOMMENDED
PRACTICE
Submitted for recognition as an American National Standard
SHORELINE SOUND LEVEL MEASUREMENT PROCEDURE
Foreword—This Document has not changed other than to put it into the new SAE Technical Standards Board
Format.
1. Scope—This SAE Recommended Practice establishes the procedure for measuring the sound level of
pleasure motorboats at a position on the shore under conditions other than stationary mode operation. It is
intended as a guide toward standard practice and is subject to change to keep pace with experience and
technical advances.
1.1 Purpose—This document specifies guidelines for sound level measurements made from the shoreline of
recreational boating areas and is intended for pleasure motorboats only.
References 2.
2.1 Applicable Publications—The following publications form a part of the specification to the extent specified
herein. Unless otherwise indicated the latest revision of SAE publications shall apply.
2.1.1 ANSI PUBLICATIONS—Available from ANSI, 11 West 42nd Street, New York, NY 10036-8002.
ANSI S1.4-1983 and S1.4A-1985—Specifications for Sound Level Meters
2.2 Related Publications—The following publications are provided for information purposes only and are not a
required part of this document.
2.2.1 SAE PUBLICATIONS—Available from SAE, 400 Commonwealth Drive, Warrendale, PA 15096-0001.
SAE J34—Exterior Sound Level Measurement Procedure for Pleasure Motorboats
SAE J2005—Stationary Sound Level Measurement Procedure for Pleasure Motorboats
2.2.2 ANSI PUBLICATIONS—Available from ANSI, 11 West 42nd Street, New York, NY 10036-8002.
ANSI S1.1-1960(1976)—Acoustical Terminology
ANSI S1.13-1971(R1986)—Methods for the Measurement of Sound Pressure Levels
SAE Technical Standards Board Rules provide that: “This report is published by SAE to advance the state of technical and engineering sciences. The use of this report is entirely
voluntary, and its applicability and suitability for any particular use, including any patent infringement arising therefrom, is the sole responsibility of the user.”
SAE reviews each technical report at least every five years at which time it may be reaffirmed, revised, or cancelled. SAE invites your written comments and suggestions.
QUESTIONS REGARDING THIS DOCUMENT: (724) 772-8512 FAX: (724) 776-0243
TO PLACE A DOCUMENT ORDER; (724) 776-4970 FAX: (724) 776-0790
SAE WEB ADDRESS http://www.sae.org
Printed in U.S.A.
Copyright 1991 Society of Automotive Engineers, Inc.
All rights reserved.
SAE J1970 Issued DEC91
Instrumentation—The following instrumentation shall be used for the measurement required. 3.
3.1 A sound level meter which meets ANSI Standard S1.4-1983 Type 1 or Type 2 specification for Sound Level
Meters.
3.2 A microphone windscreen that does not affect the overall reading by more than ± 0.5 dB(A).
3.3 A sound level calibrator.
Procedure 4.
4.1 Measurement Site—A suitable site is the shore of a body of water or dock projecting out from the shore into
the body of water, or a raft or a boat moored to a dock or anchored so that the sound level meter or microphone
is not more than 6 m (20 ft) from shore. If the measurement is made from a dock, the dock shall be of open
construction so that it presents a minimum of reflecting surfaces. The area around the microphone and boat
being measured shall be free of large obstructions or reflective surfaces, such as buildings, high
embankments, sea walls, hills, large piers, or breakwaters, etc., for a minimum distance of 30 m (100 ft).
4.2 Boat Operation
4.2.1 The applicable reading does not require that the boat be at any specific distance from the shoreline or
microphone.
4.2.2 This measurement procedure shall not be used during the 30 s time period following engine start-up and/or
preceding engine shutdown.
4.3 Measurements
4.3.1 The microphone shall be placed 1.2 to 1.5 m (4 to 5 ft) above the water, and no less than 0.6 m (2 ft) above
the curve of the shore, dock, or platform. If on a dock or platform, the microphone shall be placed near or
beyond the end of the dock or platform. If the measurement is made from a boat, the microphone shall be
held at a height of not less than 0.6 m (2 ft) above the surface of the water. A suitable boat for this purpose is
of open hull construction.
4.3.3 The observer reading the meter shall not be closer than arm's length from the microphone. Only one other
person may be within 15 m (50 ft) of the microphone when measuring from the dock or shoreline, and that
person shall be directly behind the observer reading the meter.
4.3.4 The applicable reading shall be the highest sound level measured during a period when the background
sound level is at least 10 dB lower than the maximum allowable sound level. Background sound level
other extraneous noises. Readings due to hull slaps which create intermittent sound levels shall be
disregarded.
4.3.6 When sound level readings are taken from inside a boat, 3 dB shall be subtracted from the reading to better
correlate with shoreline readings.
-2-
General Requirements 5.
5.5 The use of the word "shall" in the procedure is to be understood to be mandatory. The use of the word "should"
is to be understood as advisory. The use of the word "may" is to be understood as permissive.
-3-
APPENDIX A—
This procedure may be used for the measurement of sound emitted by pleasure motorboats in use on
waterways where sound level restrictions apply. Sound level is a function of the exhaust system, the boat hull,
the manner of boat operation, e.g., distance from shore, engine speed and trim angle, and other factors.
Background information is included in the SAE J1970 Rationale Statement.
-4-
Rationale—SAE J1970 has been developed for the specific purpose of measuring boat noise at the shoreline
of recreational boating areas. This procedure is intended for sound level measurements for all types of
pleasure motorboats. Since most complaints about boat noise originate from people situated on or near
the shores surrounding boating areas, sound level measurement at the shoreline is a key ingredient in
reducing complaints about the noise. SAE J1970 describes the necessary steps in making valid
measurements of the sound level generated by individual boats, so as to identify those boats which are
operated in such a manner to cause complaints about excessive noise.
Boat noise legislation as it is currently being enforced in more than 20 states throughout the U.S. is
based on SAE J34, Exterior Sound Level Measurement Procedure for Pleasure Motorboats. SAE J34
was originally developed by marine engineers for the purpose of evaluating the effect of engine/boat
design configurations on maximum noise, and was not intended for use as a procedure for enforcement
of boat noise legislation. It is not surprising, therefore, that SAE J34 is unsuited for enforcement
purposes. SAE J1970, on the other hand, was originated for the specific intent of providing enforcement
officials with a sound level measurement procedure by which shoreline noise levels can be accurately
measured.
Shoreline noise measurements can be performed by positioning the sound level meter on the shore at
the edge of the water, or on a dock, or from a boat which is anchored not more than 6 m (20 ft) from the
shore. Readings taken from a boat are subject to a - 3 dB correction: - 2 dB for acoustical conditions
within the boat and - 1 dB for reduced distance between the boat being measured and the microphone.
The actual sound level measurement specified by SAE J1970 is similar in many respects to SAE J34.
Because of the greater measurement distance from shore to boat in most situations, care must be
exercised in making certain that background sound levels do not influence readings. Consequently, the
background level shall be at least 10 dB lower than the maximum allowable sound level.
Since moored boats are usually located in the proximity of the shoreline, a 30 s time period is allowed the
operator in leaving from and returning to the shoreline area in which the noise limit will not be enforced.
The objective in providing the operator this time interval is to allow adequate time to leave from and
return to the mooring without being cited for noisy operation because of the short distance from shore.
Operators who generate noise complaints while in the vicinity of the mooring may likely be cited for
excessive exhaust noise which can be determined by applying the Stationary Sound Level Measurement
Procedure, SAE J2005.
Allowable sound level limits in residential neighborhoods have been addressed by past research done by
the United States Environmental Protection Agency and various European governmental agencies. This
research suggests that maximum rms levels of 75 dB(A) are acceptable in residential areas such as
those found on lake shores. Sound level surveys conducted by the SAE Marine Sound Level
Subcommittee indicate that a maximum (rms level) of 75 dB(A) provides an adequate margin above the
typical ambient so as to establish confidence in the measured level. Accordingly, it is recommended that
75 dB(A) shoreline limits be established in residential neighborhoods adjoining recreational boating
waters.
The SAE J1970 measurement procedure provides enforcement personnel with the means to identify
those boats/operators which generate noise complaints. Realization on the part of the operator that it is
his individual responsibility to control and maintain the noise at the shoreline is an important step in the
control of recreational boat noise.
Relationship of SAE Standard to ISO Standard—Not applicable.
Application—This SAE Recommended Practice establishes the procedure for measuring the sound level of
is intended as a guide toward standard practice and is subject to change to keep pace with experience
and technical advances.
Reference Section
Developed by the SAE Marine Sound Level Subcommittee
Sponsored by the SAE Marine Technical Committee and the SAE Specialized Vehicle and Equipment
Sound Level Committee
J1970
ISSUED
DEC91
1991-12 Issued
SURFACE
VEHICLE
RECOMMENDED
PRACTICE
Format.
technical advances.
References 2.
Printed in U.S.A.
Meters.
Procedure 4.
4.2 Boat Operation
microphone.
4.3 Measurements
disregarded.
-2-
-3-
APPENDIX A—
-4-
measured.
waters.
Reference Section
#45
So If You are allowed to adjust your boat for the quietest operation at idle.
What would it do to the DB level if you pulled every other plug wire in the firing rotation.
I have to believe it would still idle and because half of the exhaust pulses would be missing it would be quieter.
#46
Also the law in michigan says that silent choice is illegal then if we are allowed to adjust the boat. Why not put the silent choice in the closed mode and disable it so that it doesn't work.
then say to the cop go ahead and do your test.
#48
Actually, silent choice is not illegal if you have water injection and do not bypass the injection system. The catch is, you need to pass with only the water injection system on if you bypass the other muffler system.
#49
I cannot imagine it would be illegal. The CMI manual system is similar and seems to be okay at the current time. The catch is if Michigan passes the new WOT 50' law. Then we have some work to do.
#50
I have a question about the WOT pass, how are they going to administer it. As the captain of my boat I determine if conditions are safe to run the boat wot. I can promise you that the conditions will not be safe to run wot at the time of the test. If they want to force you to run wot and you deem conditions unsafe to run at that speed they would become liable. Also the provisions on many insurance policys state that only specific drivers can drive the boats therefore The noise police could not drive the boats themselves.
I had heard of some talk that the DNR in WI was going to do WOT tests on Winnebago but I havent heard of anyone being tested in that way.
As far as going the economic impact route, I would have to guess that there are alot more cruisers that spend money on any given weekend than performance boaters at grand haven.
Theres just more of them.
I think the biggest problem we have is that if the Police dept gets 10 calls in a day about noisy boats they feel they have been getting alot of noise complaints. In reality that's only 10 out thousands of people that really care enough to even make the call.
