Arnesons
Old 10-19-2006 | 03:00 PM
Default Re: Arnesons
Hi Rob,
isnīt the NXT is only availible with the HP700 ?
I trust Joe, I think if it is a terrible setup he will tell me.
In Miami I will ask himself.
THX Josh
toprpm is offline
Old 10-19-2006 | 03:19 PM
correct the new Merc700 only comes with the NXT drive and vice versa
frogger1403 is offline
Old 10-19-2006 | 05:13 PM
Strip Poker 388's Avatar
Rob
Originally Posted by toprpm
Hi Rob,
isn?t the NXT is only availible with the HP700 ?
THX Josh
But if he hasn't built one yet.He want know until he builds one.I would figure there would be some testing on the drive height?? 700hp on that boat would be a fun ride I am bad about just lloking and the bas stuff over the good
Frogger have you receive any 388's or 344's Hustlers with the Arneson set up yet? If so how did you like it???
Joe said there building a 388 with the 700's and was trying to get it to handle,something about cutting the second strake out instead of the last one.I would think this would help on the handling around 100mph or above ,but would hurt the cruising speeds.
Rob
Strip Poker 388 is offline
Old 10-19-2006 | 08:36 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Frogger has purchased (was at the Miami boat show this year) a 344 with 525's and ASD6 Kits.
The owner says they are running out of rpm at 102-103.
There is another one, 344, in Wendermere, FL that has the same 525 package and he also is on the bump box at 102-103.
Both have stock Merc 5 blade propellers. If someone could thin them down, only 525's, then they could probably run 105-107
Rik is offline
Old 10-19-2006 | 09:12 PM
Rob
Thats some pretty good #'s!!! I know the 344 has a differant bottom than the 388. Rik do know if there modifying the bottom on the 388's for your drives???
rob
Old 10-19-2006 | 10:32 PM
Rik's Avatar
Rik
No modifications in the mold.
As with any of the 388's that run over 100, they modify the strakes.
Other than that the bottoms are stock. The 525's have a stock bottom as well as the 625 Ilmor's I belive.
Rik is offline
Old 10-20-2006 | 02:16 AM
we received a 344 and a 388 with Arnesons so far.
Currently they are building two 388 with V10s and Arnesons for me.
Yes the 388 with more than 600s and Arnesons have a slightly modified hull.
Old 10-20-2006 | 01:52 PM
They modified my budies 388 with arnesons to make it more stable. Makes a nice tail
baja27 is offline
Old 10-20-2006 | 02:08 PM
HiPerf2000's Avatar
Attached Thumbnails Arnesons-rock_the_bay_9-06_087.jpg   Arnesons-rock-bay-9-06-082-medium-.jpg
HiPerf2000 is offline
Old 10-21-2006 | 11:39 AM
Rob
I guess there cutting the last stake out of it?
Nice looking 388,looks like its carring the bow high.Cool paint on it.
