Go Back  Offshoreonly.com > Owners Forum > Hustler
what speed for 388 w/600sci >
Old 02-14-2010 | 11:15 PM
Originally Posted by rogueman
The boat has 600s with extension boxes and bravo 1 30 pitch props. I was expecting this boat to run 90 plus but it requires alot of trim to get over 85 then starts walking and hopping. Any advice on this?
I had a 2003 388 with 575's with shortys would run 92 mph on a hot day and was on rails. Call Joe at Hustler, instead of guessing at the problem.
mean streak is offline
Old 02-15-2010 | 09:29 PM
I put -2 imco on at the end of summer with herring 32 five blades and the boat wont even come close to getting on plane ive tried 1/2 spacer's and got a little closer so now its on to 1 1/2 im sure it will now at least i hope
galex0100 is offline
Old 02-16-2010 | 08:52 AM
mwdill's Avatar
i have the ITS setup with Herring 5 blades and she comes out the hole very good, every now and then it will try and blow out.
mwdill is offline
Old 02-18-2010 | 03:18 PM
FWIW I have two 500's built to 580 hp each and running XR drives. Boat runs a solid 92 in nearly any condition. Running labbed 28 Bravo's and still not turning them more than about 5200. You need to run a neutral setting on your tabs. I find if I pick them all the way up I get porpus on the top end.......
Kieffer4 is offline
Old 02-21-2010 | 01:29 PM
I've got two 565ci pushing 720 each and before with just the xr's she would hit 92 easy now both motors are out of the boat for a refresh and dyno time and i'll see what i can get out of the old boat this summer
Old 02-21-2010 | 08:37 PM
im running 565's in my 99 388 little over 700 each with bravos. you should see 100 or REAL close
Fixxxer22 is offline
Old 02-23-2010 | 01:56 PM
Hey thanks folks. I was in Miami last week and got an earfull of ideas - where would I shop for a set of shorties, spacers and props?
rogueman is offline
Old 02-23-2010 | 09:11 PM
Strip Poker 388's Avatar
Rob
I ve seen imco shorties in the swap shop section
Strip Poker 388 is offline
Old 02-23-2010 | 09:28 PM
We got props, Hydro 5 blades and Merc 4 blades.....
SLOWRIDE-388 is offline
