Slingshot Interior & Speaker Thoughts
#31
Rob,
I was thinking about installing them upside down under the rear bolster when I get it back. Ton of room, lots of air movement and won't be exposed to water unless I got stupid with the hose and spray under the seat. It would be hard to spray water at them by accident. Is there sufficient power in the power closet to hook the amps up or do I need to run separate lines? If I mount them under the middle seat of the bolster my power wires and speaker wires would be only a few feet long as opposed to running power up the side. It would cheaper to by longer RCA's then run heavy gauge power wire and speaker wire all over the boat. Just a thought.
#32
#34
It's getting to be that time!
