32 hustler possible purchase and any input would be great
[ATTACH=CONFIG]565176[/ATTACH]
I am currently looking at a 92 32 hustler and wanted some input before I drive 1200 miles again to be disappointed by a wet/rotten hull it is completely empty so I would be using my donor boat and transfer everything from it to the hustler. current boat is a scarab panther with imco boxes and drives 550hp 502's it runs 87 mph when it was completely wet other than transom and rear stringers which were already done.
this an x race boat as well.
any of you who own these have you seen any transom or stringer rot? how do they handle in rough water etc any info would be great
I have not seen any transom rot or stringer rot in mine. Mine is a 91 and I did have it surveyed. It is a really nice hull. It handles moderate rough water very well 3-4. It is a very well balanced boat and lands very smooth, no hard jolts. It is definitely a boat you need to drive, I would not consider it a point shoot type of boat but that is what I prefer. I have extension boxes on mine ae well. My guess with your power 550s it should run into the 80s. I have only owned it for a year but have been very happy with it.
Its a great Boat , i bought a 89 a few years back only wet spot it had was in a corner in THE cockpit Floor caused by screw holes .
It was one of the fastest hulls in that time and are build for the ocean they handle rough very well , I bought mine empty as well and put in 2 brand new 320 hp diesels and Xr drives no boxes as it allready have a notch .
It did 72 mph every day I think it will do at least the same as your panther but I think it hit 90 and maybe a little more .
Don't know if a box make it faster maybe give the factory a call
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Hope this helps
What diesel manufacture did you use?
Original ad before it was stripped. Don't pay too much he stole it and has been trying to get rid of the hull for at least 6 months.
https://boats-from-usa.com/hustler/hustler-32-54025
