Ilmor fuel consumption?
Old 10-18-2011 | 04:19 PM
Question Ilmor fuel consumption?
Does anyone know what the GPH numbers are for the 570, 625, 650 and 725? Not only interested in the 100% load number, but also the 50% load and 75% load number, if possible.
A.O. Razor is offline
Old 10-19-2011 | 11:58 AM
C_Spray's Avatar
Diamond Member #001
I thought that I saw them published somewhere, but I can't find them.
My 725 delivers 3.0 mpg at 4000 rpm/60 mph in a 4,000 pound boat. That's 20 gph at slightly less than 50% throttle.
C_Spray is offline
Old 10-19-2011 | 03:01 PM
Default 3 mpg, that's not bad for a 725 hp motor:)
Yeah, so did I. Thank you.
Old 10-19-2011 | 04:27 PM
C_Spray's Avatar
Diamond Member #001
Just spoke with Ian Hawkins. Figure 50 gph at wide open for a 725 Ilmor. (70 gph for a Mercury 700SCi.... )
C_Spray is offline
Old 10-20-2011 | 08:15 PM
Would it be correct to assume that the 100% and 50% fuel consumption would be as follows?
570: 40 gph @ 100% and 15 gph @ 50%
625: 43 gph @ 100% and 17 gph @ 50%
650: 45 gph @ 100% and 18 gph @ 50%
Old 10-20-2011 | 09:27 PM
C_Spray's Avatar
Diamond Member #001
I would assume that fuel burn would be roughly proportional to horsepower, since they're all essentially the same configuration.
C_Spray is offline
Old 10-21-2011 | 10:20 AM
So do I. I've calculated the 725 gph to be 14.5 hp pr. gph, and came up with these numbers.
