Oil level rises
Old 07-24-2025 | 02:27 PM
Default Oil level rises
Dank je, Jan! Hier is een nette Engelse vertaling die je kunt gebruiken op een forum zoals TeamTalk (MasterCraft) of OffshoreOnly – Ilmor:
Subject: Fuel in Engine Oil – Ilmor 5.3L GDI (2018)
Hello everyone,
I have an Ilmor 5.3L GDI engine from 2018.
After several hours of operation, the engine oil level begins to rise. Eventually, the engine starts smoking heavily. It turns out that fuel is mixing with the engine oil. The high-pressure fuel pump was suspected to be the cause, so it was replaced — but unfortunately, the issue remains unchanged.
Has anyone experienced this before or have any idea what might be causing it?
Kind regards,
Jan van Rijswijk
Jan van Rijswijk is offline
Old 07-24-2025 | 02:45 PM
Veteran: Army
Check your fuel pressure. A failed fuel pressure regulator can cause this condition.
If fuel pressure is correct, then you may have one or more leaky injectors.
DrFeelgood is offline
