ran the mag
Took it nice and easy saturday to break in the new mill, absolutly awsome, the boat ran great but i noticed a lot of water in my oil when i checked it................First things first dont ask me what cam i run because i have already been through that crap.............I have traced the problem from the tail pipes all the way through the risers into the manifolds......The manifolds are gen 111 stainless marine, i am just beside myself........... i have just about had enough................I sure hope the guy i bought these from helps me out..........They only have 3 hours on them and i rave about how great they are any chance i get..............
Nocig, Sorry for your trouble.... are you running an oil cooler? could that be the leak? or are you saying you did you trace to the manifolds... if so, can't you just get a longer dry section of tailpipe?
i traced it to the manifolds, one side is leaking worse than the other.............
No Cig,sorry to hear about your problem.I wont give you any BS because i been throu water problems too,and there no fun,and ontop of that your hair gets thinner each time.Your lucky your in fresh water and can clean up the mess without a complet tear down,down here with the salt water in the eng.you can just as well start over,once that salt gets in the bearing all you got is a piece of junk.As far as cam goes,i run a714 714 8center mech.and if that thing dont suck water nothing will.I got a set of 13--1 pistons on shelf i ran 2 times an filled up with salt both times,just couldnt hold a head gasket with them.give up an went with 10-1 and never had another problem.Hang in there i know how you feel right now. Mag27
thanks guys, i am going to pull the manifolds and check them first, i really dont think they are leaking.....I am thinking head related but the first spot to check it exhaust.......I tore the tail pipes off first, still water in the elbows, took those off and had very little water in the back too cyinders on port side and very back on starboard.......I cant believe it would leak on both sides....Less water on starboard though...It is barly a mist but still there.......gen 111 stainless just dont ever fail....
What type exhaust and how old?
Jr. |
Nocig mentioned Gen III's and about 3 years old further up the thread.
Hope it's an easy fix Nocig, so you may get out on the water soon! |
Don't F around.
Send them to SM and get them up to par. Unfortunately, you never really know what you are getting when buying used. |
Originally Posted by tomas_wallin
(Post 2120185)
Hope it's an easy fix Nocig, so you may get out on the water soon! Jr. |
bought them new, and put 70 pounds of air in them, then through them in my hot tub, no bubbles must be the heads or head gaskets ,intake etc......
I don't quite understand... you bought these new?
By reading this statement led me to believe they were used. "I sure hope the guy i bought these from helps me out..........They only have 3 hours on them" Either way, i'm glad its not the exhaust... good luck w/ the project... these boats can be killers to the soul when this crap happens. |
Sorry i meant stainless marine but i buy all my stuff through scott from speed and custom marine.....Yeah this is frustrating but i will get it, The thing ran awsome minus the whole water in oil thing....
All back together again, testing today.................
wish me luck, good luck i mean........... |
GoodLuck.....................
And................................
just got up still trying to find my hat and my clothes in the river...........
What a pucking rocket............WOOOOOOOOOOOOOOOOWWWWWWWWWWWWWWW |
All good now...
Yes ran awsome.......
thank god......... I think i can still go down a jet size, still a little fat...... you get up way to early too eh..... |
creature of habit
creature of getting up 6 days a week at 5:00am for work...So i can barly afford my boat habit..........Have a good one..........
I am going out again today with the camera |
Thats GREAT,sounds like you got it right this time.Them 540es can be a pain somtimes,but good to hear you got the bugs out,have fun. Mag27
3 Attachment(s)
still playing with my jetting but i am getting there........I think the squirters in my catb are a little big, going to step those down a bit for this weekends run...........
3 Attachment(s)
ttt
nocig: Mike did you get all the bugs out of the steering ? Hope all is well, the Mirage has clean sides now I took the [SWITCH] name off there still some shadows left but they should fade out. All thats left to do is change the oil and it's ready to run. See you in St Clair.
She is running great but still fighting the steering problem.....I would go out now and mess with it but i dont think the neighbors like the sound of air tools at 7:00 in the morning.....
NoCig,
Your boat looks great!! I really like the classic racing style look! What speed are you at now? I can see you have plenty of space in the engine room..... Wait to see when I going to drop my engine in the boat tomorrow.... No space at all... Mange |
It just bumps 80 with good chop and light fuel.......I need prop work, just short on money.............Your boat is beautifull........I have been following your build good luck
Mike I dont know if you saw my other post ,it really belonged here but I have hynautic parts if you want to try them and see if they fix your problem ?
Hey mark, thanks for the offer but i have had all of the blocks and helm unit apart and replaced the o rings, i am complaining a lot so the wife just lets me buy full hydralic................
Originally Posted by nocigarette
(Post 2187033)
(Post 2194684)
Mike,i had lot of problems with hynatic over the years from what your tauking about to losing it altogether after 40mpi.Had a 22ft streight inbrd. with the eng. infront of the driver and after about 40 you had no steering,after compaining to the co. they sent out a new pump but did not cure it.Finally sold the boat and let sombody else fight with it. When i put Vixen together i put in a new capalono helm and love it,no power just hydralic.The guys used to complain that after the races their arms were tired but i did all the testing and felt safe with it.
Originally Posted by Mag27
(Post 2195403)
Mike,yes we do run a dominator on the mech.540 and a 850 on the hydralic eng.Was always a believer in a little lean gave a little more power,but after running into some valve problems on 4 an 6 clyinders went back and set it up according to the merc book.cant say we lost much power but had no more trouble with 4 an 6 cylinders running lean.According to what i wrote down,the power valves were 6.5 and jetting was pri.98an sec.98.This may seem rich but it was a lot safer for the eng.Now that were running her as a pleasure boat i could probably lean it out a little bit but i know this works, so far,so why fool with it.Mick, i think this is somthing you have to play with on your own.Every time i got myself in trouble i went back to the merc book an seen how they did it and usually it came out ok.Sorry i couldnt help you more,but the 540 is a great way to make power but they can make you lose your religion real quick.
2 Attachment(s)
I can hear it miss a little, i was to lean in that video fixed now, was out last night and it is a ton better
You're a menace to society!!!!........I love it!!!!........:evilb:
rained yesterday hope to get out with the camera today......got rid of the miss seems to be ok....at least the people on the canal think so......They keep giving me the thumbs up or is that the middle finger
in my experience it's usaully the middle finger...looks good.
Yah i wasnt sure but i had a feeling thats what it was............
| All times are GMT -5. The time now is 11:50 AM. |
