Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Big numbers from scorpion racing >
Old 03-21-2008 | 07:40 AM
nocigarette's Avatar
Default Big numbers from scorpion racing
Check out the dyno sheet guys, my 540 put up some decent numbers....If ya live in michigan and you are not using scorpion racing engines i think you should check them out.........Video to come soon fellas.......
Here is a link to my other thread http://www.offshoreonly.com/forums/s...d.php?t=182629.....
This sheet was run with pump gas, and all my belts on alt, water pump etc.....After there tweaking it had huge gains....
nocigarette is offline
Old 03-21-2008 | 08:24 AM
Here is the video, she made 700 hoarse at 6000 rpm...That was after frank and phil tweaked it in.......
http://www.acidplanet.com/artist.asp?pid=1095753&T=6891
Old 03-21-2008 | 06:16 PM
24degrees's Avatar
Dang........
24degrees is offline
Old 03-22-2008 | 09:22 PM
h2oboater's Avatar
Mike now that's how you do it, the dyno takes all the guess work out. Did you leave your cam in ?
h2oboater is offline
Old 03-23-2008 | 07:48 AM
Yup the big cam made the big power.......My vote is it stays....
Old 03-23-2008 | 11:27 AM
bouyhunter's Avatar
Looking good Mike.
Mine will be ready to go in a week or two, but I'm not even thinking about the numbers you're turning.
bouyhunter is offline
Old 03-23-2008 | 07:48 PM
Sounds like alot of fun with that kind of power.
Hope you get the speeds your after.
Len S is offline
Old 03-24-2008 | 06:59 AM
Not really after any more speed, she runs real good now.....I just did not want to spend half my summer trying to tune the boat.....With the guys at scorpion i know it is done and i can bolt it in and go......
nocigarette
08-20-2008 07:00 PM
nocigarette
05-27-2008 04:19 PM
Strip Poker 388
2
04-28-2007 05:20 PM
SOX
09-29-2006 09:28 PM
MANITIE
OPA/The Jersey Boyz
7
08-29-2006 03:47 PM
