Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Rebuilding a 27 Sedan >
Old 01-29-2012 | 04:09 PM
Default Rebuilding a 27 Sedan
I picked up a early 70's 27 sedan last month in Pa. & am planning to restore as a resto-mod with modern Mercury Smartcraft -fly by wire motors & drives, modern retro gauges, LED lighting, etc..
It was originally done in purple but someone had it painted yellow & painted the name "The Viking" on the side. It looks as it had another name when it was purple that is lightly bleeding through the yellow in places. It also looks as if it had been repowered from the original Volvo's & it seem from the fuel filters mounts, wiring, & Merc-cathode remnants that the last set of motors (removed prior) were Mercury's.
I am looking for pictures of the rear bench seat & sun pad as they were removed & any history of the boat.
Flitzr1 is offline
Old 01-29-2012 | 05:13 PM
h2oboater's Avatar
Sedans use a stand alone bottom seat with the backrest pad that snaps on the engine bulk head, just like rear seat in my Donzi Doral. here is what the seat brackets look like. you could make them out of any type of tubbing also.
Attached Thumbnails Rebuilding a 27 Sedan-back-seat-1.jpg   Rebuilding a 27 Sedan-mag-bolster.jpg   Rebuilding a 27 Sedan-mag-sedan-45.jpg
h2oboater is offline
Old 01-29-2012 | 10:11 PM
Thanks for pic's
I have the helm seats with arms rather than the dropout bolsters. I have sourced all new hardware for those. i'm still not warming up to the stripe interiors these boat carried when they were young.
I think making the bench seat frame out of extruded 0.50" x 2.0" flat Aluminum bar stock with a radiused edges would be better than tubing.
I'll post pictures after i research how to attach pic's.
Flitzr1 is offline
Old 01-30-2012 | 01:05 AM
h2oboater's Avatar
Thanks for pic's
I'm paying extra for a new candy striped interior for my sport, I still like the classic look.
Old 01-30-2012 | 06:47 AM
With all the sewing hours per stripe I would guess so.
If you are using the buckets in your Red & white pic. let me know I have 4-6 of those plastic shells that were miss ordered for another project. If you are going with new foam make sure it is anti fungal. They put it in before the master foam buns are produced. Also make sure they use an expanded vinyl not the cheap fuzzy backed stuff.
Flitzr1 is offline
Old 01-30-2012 | 08:54 AM
I bought and repowered my sedan in 94/95. good luck with the resto. post a lot of pictures. I love my boat.
27sedan is offline
Old 01-30-2012 | 09:28 AM
h2oboater's Avatar
That's not my interior just a pic I have. I built a set of bolsters that are at the upholstery shop now. I plain to use most of my sports old interior [in these pic's] in my Sedan.
Attached Thumbnails Rebuilding a 27 Sedan-mag-1etq%7E%7E_12.jpg   Rebuilding a 27 Sedan-mag-2dq%7E%7E_12.jpg
Old 02-01-2012 | 04:11 PM
Hi again, we just finished wet sanding the whole boat with 1000.
I have to replace 1 of the fuel tanks & am trying to locate a source where I can get a D & M sight gauge. Can't find any info on them on internet??
Any quick guide on posting pics would also be of assistance.
Flitzr1 is offline
Old 02-01-2012 | 04:15 PM
Awesome. One of my favorites. Good luck.
Mike S. is smiling
Twin O/B Sonic is offline
Old 02-01-2012 | 09:38 PM
scippy's Avatar
I just pulled the rear benchseat from my sport..(needed the room because I'm lowering the floor & cutting the stringers down in the cockpit) found alot of rot in the lower section of the bench seat (balsa core was definately not sealed) more work on top of all the other stuff.......but I enjoy it!!
Attached Thumbnails Rebuilding a 27 Sedan-img_7752.jpg   Rebuilding a 27 Sedan-img_7751.jpg   Rebuilding a 27 Sedan-img_7749.jpg
scippy is offline
