Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Nose Cones ??? >
Nose Cones ???
Nose Cones ???
Old 02-20-2012 | 11:20 AM
Default Nose Cones ???
Anyone have personal experience with nose cones on a bravo drive 27? My prop slip is around 18% so I am thinking about it. Is there any difference between imco/hydromotive etc?
Thanks - Marshall
MDonziM is offline
Old 02-21-2012 | 10:33 AM
I have been doing some reserch for a friend with a 32 Stuphen with Bravo's. What I am finding out is, boats with a high X like nose cones. Boats with a low X need the blunt stock Bravo lower. With the high X you will get a better flow to the prop with the nose cone, With the lower X the drive will need more trim. The blunt lower is desined for more trim in deeper water not effecting the water flow over the prop. Hope this helps.
Dirty Pearl is offline
Old 02-21-2012 | 02:01 PM
Thanks DP - what do you consider a high x? My prop shafts are 5" below the bottom at the drive and about 1" above the keel bottom.
MDonziM is offline
Old 02-21-2012 | 08:35 PM
I believe nose cones like running close to the surface. I think yours is that way. Stock Bravo lowers are for props running deep in the water. Like family boats, non high performance style boats. I ran Hdromotives on my Maltese with TRS and she ran great,
Old 02-21-2012 | 09:19 PM
I was thinking about hydromotives, thx.
MDonziM is offline
Old 03-13-2012 | 04:17 PM
I am instaling a set of leading edge on my 32 active thunder as we speak, my thunder has a high x and another guy on here put a set on his 32 active thunder and picked up 4 mph. they help you mostly over 80mph boats.
rssteiny is offline
Old 03-15-2012 | 12:27 PM
CIG3's Avatar
Hysromotive cones are really nice.
CIG3 is offline
