Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
starfire tank access >
Old 10-01-2012 | 08:06 AM
Default starfire tank access
i think i broke a pickup off the inside of my fuel tank. is there an access for it or do i have to cut the floor out of the boat. its a 1980 starfire. any info would be great
thanks
cig92 is offline
Old 10-03-2012 | 07:37 PM
The floor over the tanks should be 2 pieces of plywood, just unscrew and pry out. There is a piece of mahogony down the center that sits on the stringer. There is a pic in the sport hull thread that Pete"Skippy" just posted that shows a replacement tank. I replaced both my tanks 2 yrs ago if you have any questions.
MDonziM is offline
Old 10-06-2012 | 09:03 PM
thanks for the info, i will check it out tomorrow.
cig92 is offline
Old 10-08-2012 | 03:12 PM
ended up being a bad fuel pump, third one on that motor in the last 5 years. never had to replace a fuel pump on any other motor. the pump was still pushing but not enough. the weird thing is that the diaphram was still good, the cam is good and the arm on the pump is good.
cig92 is offline
Old 10-08-2012 | 03:35 PM
when was the last time you changed your fuel filters?
88bullet is offline
Old 10-08-2012 | 07:06 PM
Thats strange, but a lot easier to replace a pump than a tank... I run superchargers so I have fuel regulators and pressure guages so theres no guessing. Whats the gph of the pump? I replaced a pump a couple of years ago and this spring when the motor was gone thru the cam lobe was scored pretty bad... tough to say.
What props do you run on your starfire?
- M
MDonziM is offline
Old 10-09-2012 | 10:06 PM
mdonzim- the motors are 500hps with dart aluminum heads,cam,cmi sport tube full length headers etc. the pump is standard hp 500, looks like a carter 130 gph but not sure. it's the style mounted to the water pump. as for props, i'm now running a pair of custom bblades 28 pitch hydro's. the boat runs just shy of 90 mph
cig92 is offline
Old 10-10-2012 | 01:01 PM
Cig,
What rpm do you run the hydro 28's to? I'm losing grip somewhere because I turn stock bravo I 32's to 5k and have only seen 84-85mph.
MDonziM is offline
Old 10-10-2012 | 09:56 PM
5600 rpm at 10-12 percent slip. your numbers are correct at 15 percent slip. not sure what prop you are running, what drive height or drive. mine are standard bravo's and if you are running xr's you can subtract 3 mph right away. from my experience, the hydro's run much better and always faster. my slip numbers are very low and the boat is dialed in pretty well, it has run good from day one. these are also gps numbers, not a junk speedo. what is your set up? kevin
cig92 is offline
Old 10-11-2012 | 08:31 AM
Hey Kevin,
Last yr. after restoring my Mag my best speed was 84.5 mph. My power is 420Merc. 454 build with B&M 174 blowers w/ 5lbs of boost. Should be right around 550hp. Bravo drives, 17 1/4" X-dim 32"b1 props from bblades untouched. 70deg, 1/4 tank of gas. Heres the rub, port motor only made 4600 rpm while stb could go to 5200. So over the winter we notice some piston wall scoring on 1 cylinder so we found a new block and completely rebuild the motor now with Brodix heads. Now the motors should be 575hp. Also put hydromotive nose cones on my drives. After all the break in etc. same exact #s..... Now the super charger on the port motor is only putting out 3lbs of boost. Same 500rpm difference between motors. Crap! Dont want to send the sc out to california mid summer so I just run the boat as is. After checking ignition, timing and other possabilities, decide to put a smaller snout pully on to increase boost on port motor. Got 6lbs of boost, but almost identical #'s... WHAT? So the current theory is that the port super charger is super ineffecient and in need of rebuild. You would think the added boost would translate to added rpm/power but no. I actually thought there could have been some kind of rev limiter ignition module issue but about a week ago I went out in a good 2-3' chop and really got on her in a following sea and the motor will spin to 5k+ rmp.
Anyway, I'll talk to brett over the winter about bravo vs. hydro and hopefully the sc is the issue and next yr. I'll make my pilgrimage to 90mph again. I'll check with my local prop guy and see if he has a set of hydro's I can borrow. Oh yea, almost forgot, I had a big, big improvement getting on plane , tracking and overall handling turning my props inward.
- Marshall
MDonziM is offline
