Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Sedan speed question >
Old 06-25-2014 | 10:16 AM
Default Sedan speed question
What would the approximate top speed of a 27 sedan with twin 225 HP motors through Volvo out drives be?
murfman is offline
Old 06-25-2014 | 11:53 AM
h2oboater's Avatar
If the sedan is in stock condition with the Volvo drives it should run around 48 to 52 mph..
h2oboater is offline
Old 06-25-2014 | 12:06 PM
Thanks. It has small block Chryslers. I plan on building a pair of 350 - 400HP motors. Hoping for mid - high 60s. I know the Volvos aren't going to help, but I'm a MOPAR guy and like the small blocks
murfman is offline
Old 06-25-2014 | 12:22 PM
h2oboater's Avatar
With 400hp & stock X dim you may see 60mph with today's props. My sport has 400hp 355cu Chevy engines, & Volvo drives with a 3" raised X with 23p Mirage props, I only run 68 to 70mph on Jeff Hall's GPS.
Old 06-25-2014 | 12:29 PM
My sedan has 2x250 hp at the prop with bravos. I do a solid 65. let's see some pictures.
27sedan is offline
Old 06-25-2014 | 12:35 PM
68-70 would make me very happy. With the easy availability of 4" Stroker cranks I can build easy 402 Cu In motors with Indy iron heads and make 400HP. I was already thinking about the 290 transoms to get trim so raising the X is not out of the question either.
murfman is offline
Old 06-25-2014 | 12:44 PM
It's definately a project bits it's all original and not hacked up
murfman is offline
Old 06-25-2014 | 01:37 PM
h2oboater's Avatar
I would just make your own power trim using Merc OB trim cyl & Merc pumps it's simple & easy if you feel you need power trim rather than changing the drives to 290 Volvo drives. I have this trim set up on the X-18 Donzi works great, been making them for my boats since 1976. On my sport I dont have any need for power trim, I just keep it on the second pin, I get all the speed I need. I like to keep things simple..
Attached Thumbnails Sedan speed question-volvo-trim13.jpg   Sedan speed question-volvo-trim-12.jpg   Sedan speed question-dsc05205.jpg
Sedan speed question-mag-transom2.jpg   Sedan speed question-mag-transom-3.jpg
Old 06-25-2014 | 09:29 PM
How didraising the X affect the performance of the boat aside from
Top speed? Did it change the planing or handling characteristics at all? Does it still pull out
Of the hole well? I don't want to give up other areas just to gain top speed. If it does not make a big difference in other places I'm all for it
murfman is offline
Old 06-26-2014 | 08:17 AM
----Ive seen H20s trim set-up and it really slick........Bill S
olredalert is offline
