Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Rubber cockpit floor >
Old 09-13-2014 | 03:51 AM
Default Rubber cockpit floor
I would like to cover the cockpit floor with rubber to avoid dangerous slips too
I look forward to your suggestions and experiences
Thank you
Giovanni
giocariello@gmai is offline
Old 09-13-2014 | 10:01 PM
Plum_Crazy's Avatar
Check out a product called Deckadence.
Plum_Crazy is offline
Old 09-13-2014 | 10:34 PM
mr vinyl's Avatar
o
Giovanni Look into Lonseal www.lonsealspecialty.com ,Pirelli Flooring, and then carpeting as a final touch. Sorry I didn't get back to you sooner. Bud
mr vinyl is offline
Old 09-14-2014 | 02:56 AM
Tks for your suggest...
Bud give me an hand to the right product in that web site...
Old 09-14-2014 | 10:06 AM
mr vinyl's Avatar
THEY ALL ARE THE SAME PRODUCT EXCEPT DESIGN,PIRELLI SAMPLES SHOULD BE AVAILABLE THERE. Lonseal MIGHT SEND YOU A SAMPLE KIT IF IT WENT TO YOUR MARINA.
BUD
mr vinyl is offline
Old 09-18-2014 | 04:29 PM
You might also want to check out the non-skid flooring from Vetus called "Happy Elephant":
http://www.vetus.com/v-quipment/mate...-x-120-cm.html
Ben
70open28 is offline
Old 09-18-2014 | 04:38 PM
ROB FREEMAN's Avatar
Just for the record any rubber product verry suceptable to water , make sure you're product and usage are going to be feasible , we moisture barrier all areas before installing any rubber floors ect ? Just saying
ROB FREEMAN is offline
Old 09-19-2014 | 01:14 AM
I will have in mind your suggestion
Tks
Old 09-19-2014 | 07:32 AM
What about having a spray on bedliner applied? They come in different colors and hold up extremely well, and now with the advent of UV stabilizers hold their color.
Jonesyfxr is offline
Old 09-19-2014 | 01:32 PM
Thank you
Giovanni
Giovanni, my name is Ian Toll and I have just spent 4 years part time re building my Magnum27 Sport " SideWinder" with all new Teak deck inlay and cockpit sole for a real non slip classic floor.
This is a lot of work and not cheap to do, but my pleasure is in the build and the ownership.
However if you would like a similar look but without the full cost or the maintenance of a non slip wooden deck my I please suggest that you take a look at the website for Teaknotek.
Their office in Italy is Via Guidetti 45/1, 44100 Ferrara Italy.
Good luck with your project.
Kalaazar
Kalaazar is offline
