Diesels/
Wellllll......I have had this conversation with Randy before. Depending on the weight of that C32, it is very very doable. Ideally the 55' would be rigged with power that weighs 2000lbs or less per side. I am no diesel genius but I would bet the C32 weighs more than that. You also could rig a single diesel powerplant putting out 1800 HP connected to 2 seperate surface drives. Performance would be directly related to the overall weight of the power.
I believe the 39' with diesel power ran in the mid 80's.
BTW, these would be your C-32's
Dry weight w/ gear 7000 lbs. each.They push an 80' along ok.
