Go Back  Offshoreonly.com > Owners Forum > MTI (Marine Technologies)
Come on MTI boater let's see your boats >
Old 12-11-2005 | 08:07 PM
  #81
Brad Zastrow's Avatar
Default Re: Come on MTI boater let's see your boats
The hardtop can be attached in less than 5 minutes. The scoop will be fully functional. The scoop was the hardest part of the conversion. A portion of the deck will be removable to allow the air scoop holes into the bilge area. Even with the pleasure version there is the front half of the top still on the boat for protection. The CRC conversion was inspiration for this boat.
Brad Zastrow is offline
Old 12-11-2005 | 08:21 PM
  #82
Sean H's Avatar
A to Z
where will it pull air when the top is off? scoops on the hatches?
Sean H is offline
Old 12-11-2005 | 08:34 PM
  #83
WeaponX's Avatar
Top step looks removable.
WeaponX is offline
Old 12-11-2005 | 08:43 PM
  #84
ChiToWn TapouT's Avatar
Put the top up its starting to rain turn on the air too.
ChiToWn TapouT is offline
Old 12-11-2005 | 08:45 PM
  #85
Sean H's Avatar
A to Z
i would guess that is what blocks the air intake when the top is off, i was wondering where the air would come from when that step is in place....
Sean H is offline
Old 12-12-2005 | 12:00 AM
  #86
WeaponX's Avatar
I thought the step flipped up like a Porsche wing at speed what else?
WeaponX is offline
Old 12-12-2005 | 10:08 AM
  #87
We are installing scoops in the hatchs for the blower motors as they are too tall. We are using the new style areodynamic scoop with the air cutout in the back. We do not want to cut the hatches until the motors are set in place. Those 16:71 superchargers do not leave much room for error with the hatch fit.
Old 12-12-2005 | 11:33 AM
  #88
Sean H's Avatar
A to Z
i forgot you putting those tall motors in it...
Sean H is offline
Old 12-12-2005 | 01:53 PM
  #89
44MTI's Avatar
Congrats, your conversion looks great so far.
If you chose to, you should be able to install the motors without putting the scoops on. They have done several with the same set up without scoops. In fact, we are not putting them on my new boat which will have a quadrotor setup which is the same height, but alot wider.
44MTI is offline
Old 12-27-2005 | 08:24 PM
  #90
lucky strike's Avatar
I guess "Little G" sold his MTI. It's on a lift in North Miami, beautiful boat
LS JR.
lucky strike is offline
