Bully Dog Products!!!
Triad Performance Marine is now a distributor for Bully Dog Industries.
I have added over 200 Bully Dog products to my website, but please do not hesistate to contact me with any questions you may have.
Powerpup Triple Dog with outlook monitor for 03-05 Ford 6.0L - $697.07
Details and Order link: http://www.tpmarine.com/index.asp?Pa...odID=1011&HS=1
Never buy another programmer...one programmer programs Dodge, Ford, and GM. You can also upgrade the programming as patch's and new programs are released by each manufacturer.
602 438-1361
[email protected]
602 438-1361
[email protected]
Take your Duramax to a whole new level, with Bully Dog's Triple Dog Outlook Combo pack.
Powerpup Triple Dog with outlook monitor for 01-05 Duramax - $697.07
Details & order link: http://www.tpmarine.com/index.asp?Pa...OD&ProdID=1042
Programming for the 06 models will be released shortly and all you have to do is log onto Bully Dog's website to download it once it is available.
Cool
Cool
Take your Dodge Cummins to a whole new level, with Bully Dog's Triple Dog Outlook Combo pack.
Bully Dog Power Pup Triple Dog w/Outlook Monitor Dodge Cummins - $697.07
http://www.tpmarine.com/index.asp?Pa...OD&ProdID=1161
Originally Posted by dukenrock
Could you use this in conjunction with the Banks system? (2004 600 Cummins)
Yes, you could add the bully dog programmer to your truck; of course you might need to consider transmission mods or upgrage your fuel injectors to handle the additonal programming/horsepower, but it can be done.
You could just go with the bully dog and download the "crazy larry" program from bully dog's website(no additional charge) and you will be making additonal 200hp with the bully dog alone.
Let me know if you have any other questions.
I've already got an ATS Torque Converter with a HP Valve Body modification. 200 hp!! Does this just plug into the main module or do I plug into the wire loom where the Banks is now? Also, is this going to starve the fuel without bigger injectors? Can you send me one to try and if I like it I'll buy it
The bully dog is uploaded via the diagnostic/OBDII port and will not interfere with the six gun.
I have not added all the detailed information to my website just yet, but here is a link to all the fuel injector options:
http://www.tpmarine.com/index.asp?Pa...S&Category=319
If you decided to buy one and do not like it, I will refund your money...
Bully Dog Power Pup Triple Dog - Dodge, Ford, GMC - $464.98
Order link: http://www.tpmarine.com/index.asp?Pa...OD&ProdID=1004
Do already have a set of gauges and just need the programmer, well here you go. 3 programmers in 1.
Take your Ford Power Stroke, Dodge Cummins or GM Duramax to a whole new level with Bully Dog's Triple Dog. No one can touch what Bully Dog is doing. Bully Dog is the only manufacture that can offer you a downloader that will increase horsepower levels on the latest Dodge Ford or GM trucks with the same downloader. Bully Dog is also the only manufacture that will allow you to change horsepower levels inside the cab with a downloader.
The Triple Dog works on the following trucks:
Dodge 03 & UP
Ford 6.0L 03 & UP
GM 01 & UP*
Dodge 03 & UP
Ford 6.0L 03 & UP
GM 01 & UP*
