-   New Products and Member Discounts (https://www.offshoreonly.com/forums/new-products-member-discounts-139/)
-   -   Gimble Rings & bell and....... (https://www.offshoreonly.com/forums/new-products-member-discounts/139065-gimble-rings-bell.html)
boatnt 11-02-2007 06:20 AM
Adrian
got the rings/bellhoushings .thanks for the great service.
Tom
randy carlson 11-02-2007 07:19 AM
Adrian, got my gimball assy's thanks , do you still have two sets of those 496 ex manifolds? Randy 616-218-7388
teaguecustommarine 11-03-2007 11:44 AM
yup, sure do
i will call you on monday
Scarab3DMC 11-04-2007 06:19 AM
I need 4 pillow block motor mounts, 14mm oil drain hose kit and 4 sets Stainless Marine exaust gaskets..can you help ? Dave.440-773-1844
teaguecustommarine 11-06-2007 10:42 AM
i have all that stuff. I will give you a call
Matt M 02-10-2008 08:13 PM
Do you have any of these left? Thanks, Matt
teaguecustommarine 02-11-2008 10:19 AM
sure do. give me a call and we will get the info we need to get one out to you
ask for Adrian
thanks
Bangin Bottom 02-13-2008 10:18 PM
I have a Formula 271, a big heavy boat for single power. The gimble seems to be really tight but it leaks BAD around the top pin/bushing. Do you have a kit or a service to upgrade this? Sending you the entire assembly is not a problem. I hate to spend a lot of money just to fix a problem without getting an upgrade of some sort.:cool-smiley-026:
teaguecustommarine 02-20-2008 02:52 PM
there is a Helmut and ring upgrade you can purchase but without seeing where the leak is i couldn't tell you if would it would fix your problem. I dont want you to spend money you dont have to and not fix what you have going on. you need to find the leak first and then do the upgrade if you want to but if you have been running the boat for a while and have not had a problem with the transom assy then as much as i want to sell you something I'm going to have to say dont spend the money if it isn't broken
let me know what you find
thanks
Adrian
SKRAMER 07-30-2008 06:39 AM
Originally Posted by teaguecustommarine (Post 1847615)
We have NEW take off Gimble Rings with the Bell & trim limit/sender
on the shelf and ready to go.
Merc part #822374A4
Retail from Merc for $849.90
your from TEAGUE CUSTOM MARINE for $424.95
thats 50% OFF
Do you still have any of these?
