I'm BACK AND CLEANING HOUSE
#191
Offshoreonly Advertiser
We mainly sell IMCO Steering. Is your application a single or a twin?
Single engine, dual ram "outside" kits, starting @ $2357.86
Twin engine, dual ram "outside" kits, starting @ $2476.06
+ inside brazil adapter hose kit or the a full hyd. inner hose kit.
-Eric
-Eric
#192
We do not have 2 engines worth of good used systems in stock.. Make sure if buying a used system/s, they are not corroded nor cracked! I hear of too many people getting ripped off buying used exhaust kits.
-Eric
#193
Je pistons 257970, bbc flat top pistons *4.310 bore
JE PISTONS 257970, BBC Flat top pistons w/ 51s 180 wall std pins.
http://teaguecustommarine.com/em0011...p-pistons.html
Bore: 4.310
Stroke: 4.000
Rod length: 6.385
Compression height: 1.395
Piston weight: 586
$500.00 for pistons and pins, Rings extra.
Give me a call or order online! -Eric
[ATTACH=CONFIG]532557[/ATTACH][ATTACH=CONFIG]532564[/ATTACH][ATTACH=CONFIG]532563[/ATTACH][ATTACH=CONFIG]532562[/ATTACH][ATTACH=CONFIG]532561[/ATTACH][ATTACH=CONFIG]532560[/ATTACH][ATTACH=CONFIG]532559[/ATTACH][ATTACH=CONFIG]532558[/ATTACH]
Bore: 4.310
Stroke: 4.000
Rod length: 6.385
Piston weight: 586
#195
The Original California Car Blade
The Original California Car Blades are now on extreme blow-out here at Teague Custom Mairne.
Let's just say we have way too many of them and they need to go.
Christmas and the rainy season are coming up, make drying a piece of cake!
CCD-20039: 18" blade (blue) and extension pole kit. $21.00
CCD-20002: 12" Blade (purple). $15.00
CCD-20036: Blade to pole adapter kit. $4.00
CCD-22012: Microfiber wash mitt. $5.00
CCD-1OFEACH: includes 1 of each of all of the above. $38.00
Give us a call and get yours today.
At these prices they will not last long!!
TEAGUE CUSTOM MARINE INC.
661-295-7000
[ATTACH=CONFIG]533165[/ATTACH][ATTACH=CONFIG]533166[/ATTACH][ATTACH=CONFIG]533167[/ATTACH]
[ATTACH=CONFIG]533168[/ATTACH][ATTACH=CONFIG]533169[/ATTACH][ATTACH=CONFIG]533170[/ATTACH]
#196
661-295-7000
#197
Thanks TCM !!!
#200
2x Good used Mercury Racing 850sci, 1025sci, 1075sci, 1200sci Dampers.
$749.97ea (Mercury retail @ $2106.05ea)
http://teaguecustommarine.com/em0011...-take-off.html
-Eric
[ATTACH=CONFIG]542880[/ATTACH][ATTACH=CONFIG]542881[/ATTACH][ATTACH=CONFIG]542879[/ATTACH]
-Eric
