More Shocking
Old 02-08-2008 | 12:54 PM
CPPerformance's Avatar
Default More Shocking
The MSD 8.5mm Super Conductor Wire is "the" performance wire.Engineered from the inside out, the 8.5 offers everything you have everwanted in a wire; incredibly low resistance without electronic interference! In a single 12 inch length of Super Conductor Wire there is only 40 - 50 ohms of resistance! That is the lowest resistance of any helically wound wire. To accomplish this, we use a copper alloy conductor due to it's great voltage carrying capabilities. The low resistance results in less loss in spark energy so more reaches the spark plug. The conductor is wound extremely tight around a special center core. So tight in fact, that there is over 40 feet of conductor wrapped into a single foot of plug wire. This winding procedure, combined with a ferro-magnetic impregnated center core, produces an extremely effective Electro Magnetic Interference (EMI) "choke".
This choke, or suppression capability, keeps the EMI inside the wire where it cannot interfere with other electronics on your vehicle. The outer sleeve that surrounds the conductor assembly is just as impressive. A proprietary blend of silicone and synthetic material produce a sleeve that is highly resistant to high heat as well as abrasion and tears. The MSD 8.5mm Super Conductor Plug Wire is available in Universal Kits and Bulk Lengths.
Dual Crimp Terminals
All of the MSD spark plug terminals feature "Dual Crimp" terminals. As the name implies, the terminals feature two crimps: One for the sleeve of the wire and another separate crimp to grasp the conductor of the wire.
By having separate crimps, the conductor doesn't need to bent 180° and get squeezed between the terminal and sleeve. The individual conductor crimp produces a more secure crimp and there is less chance of spark arcing to the engine block or exhaust through the boot. In fact, we feel so strongly about our Dual Crimp terminals that every factory crimped plug wire is guaranteed not to "pull off" for FIVE years!
CPPerformance is offline
Old 02-14-2008 | 09:43 PM
Available for many applications, post or call us today for some great prices.
