Two Piece Valve Covers from KE Performance!
KEPP,
You should recommend the baffle kit for the breathers. My breathers were leaking and I purchased the baffle kit and it solved the problem. FYI, your customer service is arrogant and think they know it all!!! I suggest you should take the approach with your customers!!!!!!
I have to rescind my prior statement, KE has been more then helpful. KE has gone through the trouble of OVER NIGHTING me new covers and bases as well as calling me every day and asking if things are ok and if they can do anything for me. I have to say their customer servicer has been 150% to the positive. I would like to THANK Jeff and Scott for their help as well as the employee's for KE.
Now thats cool!!!!
Yes the optional dual baffle insert is a part #620-154026 and sells for $12.95 each. These are designed to be held in the later model breather extensions that have a retaining ring machined internally on the breather extension.
I'm having the same problem with oil puking all over the bilge from the KE valve covers... Eddie Young just built my motors and they are just about a year old.. First it was the Port motor and now the Starboard motor is leaking oil like sieve...
We had to pull the boat out this weekend and take to the shop down here at the lake to try and get this situation fixed.
I do like the two piece design but can't put up with all of the oil that's leaking into the bilge...
If KEPP can give me some suggestions on how to correct it it would be greatly appreciated... Jim
Cool to see there is somewhat of customer service left these days. Now if you can get Drew Marine or West Coast Marine to follow in these footsteps I'd kiss your a$$!!! I doubt that will happen so I wont be puckering up anytime soon!!!
Well I just want to make sure were talking about the same things here. Do the motors have blow by? If so you would want to speak with Eddie more about that as he may have answers. There's nothing that lets just say wears out that would cause the covers to not leak and then later on start to leak unless they came loose or broke or??? But if you can narrow down a bit where you think the actual leak is and give us a call we will do our best to help you resolve it.
I see where Eddie mentioned in another thread on these valve covers that the new bases he has been getting have a rubber gasket on top of the rails where the top meets the base? Is that something that can be added to the ones that
I presently have?
I'd like to call and talk to someone just let me know who to ask for or they can call my cell.
Jim (402-510-1694)
Last edited by fountain4play; 07-18-2011 at 12:36 PM. Reason: Added rubber gasket info from Eddie
My new set that KE sent to me over night work great now, I have run them once and not super hard but where the old ones would have made a mess the new ones do not leak anything!!! Thanks KE I appreciate the customer service and the covers are a great product!
