exhaust question?? >
exhaust question??
exhaust question??
Old 07-08-2005 | 06:26 AM
Chuck's Avatar
Default exhaust question??
On my 36 cat what would be the the best way to meet the current 90db. stationary test? 525 Mercs with the standard Nor-Tech exhaust. Thanks P.S. On my previous boat with a similar style of exhaust ( just smaller diameter), the CMI clamp ons got my 496's to 88db. at idle.
Chuck is offline
Old 07-08-2005 | 07:47 PM
Mentalpause's Avatar
Default Re: exhaust question??
May want to read through this thread Chuck. Also, Wiggler is doing a lot of testing of Nortechs with different muffler combinations, so it might be worth giving him a call.
http://www.offshoreonly.com/forums/s...d.php?t=106039
Mentalpause is offline
Old 07-08-2005 | 08:39 PM
Chuck's Avatar
thanks John
Chuck is offline
Old 07-09-2005 | 04:49 AM
GGB makes the only 6" clamp on extreme right now. will probably bring you close to 90, they also have a new 6" insert that I think works and looks alot better, that is 19" long. I'm assuming you have the wet cmi exhaust . no angled water dumps at top corners. CMI has a new sound elimination system but requires all new tailpipes and they have to install it and is very expensive. I would try the 6" inserts first. Nortech is working on a retrofit turndown for higher hp applications, but a 525efi should be around 100db;s open ggb's will drop 10-12 db's.
Buddy OO is offline
Old 07-09-2005 | 09:02 AM
Chuck's Avatar
thanks wiggler
Chuck is offline
hpy540
8
11-22-2005 07:14 PM
THE GOOD STUFF
03-03-2004 09:17 PM
formula1
05-25-2002 07:59 PM
thisistank
Baja
17
03-24-2002 10:50 AM
