New to me 380LE >
New to me 380LE
New to me 380LE
Old 01-11-2011 | 10:34 AM
  #61
LAriverratt's Avatar
well at least it'll be running soon. should push that thing ok i'd think..do ya know the weight on the hull???? what did ya do with the big hp motors????
LAriverratt is offline
Old 01-11-2011 | 11:16 AM
  #62
havn't built them yet. Gonna finish this one and put it up for sale. I have my eye on another one that the big power would be great in.
This boat should scoot along just fine with these engines. And if someone doesn't want them, I will be happy to keep them. They are nice conservative mills.
jeff1000man is offline
Old 01-11-2011 | 01:36 PM
  #63
Engines are back from the shop. Good job RMBUILDER on the cams. These numbers are with as cast iron oval port merlin heads. We cahnged valves to inconel and springs to comp, otherwise these engines are with out of the box, as cast parts.
only about 9.3:1 comp. 750 carbs and dual plane intakes. 496CI.
428,431 HP at 5300
480, 485 lbs at 4400
Huge torque curve between 3000 and 4000
I really should be putting these in my sea ray with those numbers, but I wan't to see how these little engines will make this boat run.
Looks like maximum fuel consumption is around 30gals an hour at WOT.
Good job to Owens racing for perfectly matching machine work to get the numbers to almost match.
They are getting dressed and ready to install again. Hopefully this week.
Here is one sheet and a comparison against the old cams I had in there.
You typed 428/431.
Dyno says 528/531. Don't sell your self short judge
joew. is offline
Old 01-11-2011 | 09:59 PM
  #64
engines are almost dressed and ready.
Gonna try to put them back in tomorrow and start buttoning her back up. We will probably get a warm day here again pretty soon so I can test it out.
Old 01-12-2011 | 12:01 AM
  #65
Your mouth to Gods ears buddy..
HTRDLNCN is offline
Old 01-12-2011 | 07:54 AM
  #66
I wouldn't mind getting one here as well...i need to go get some data on the boat so I can get some new props plus blow the soot out of the thing
are you looking at a cat or strictly V for your big HP's??
Old 01-12-2011 | 09:46 AM
  #67
i all ready found it. it is a v hull
Old 01-12-2011 | 11:21 AM
  #68
are you willing to share info on your new project yet
Old 01-12-2011 | 12:04 PM
  #69
Not till either after I get it bought or someone beats me to it.
Old 01-12-2011 | 01:41 PM
  #70
I understand
