Tie bar
Old 04-24-2011 | 09:06 AM
Default Tie bar
Is there any truth to the rumour that these cats tear the tie bar off when coming off plane at a high rate of speed ? is it the 36 and the 43 ? any help would be appreciated
whataride is offline
Old 04-24-2011 | 10:54 AM
Chuck's Avatar
I have never heard of anything like that in the six years I have had a Nor-Tech cat.
Chuck is offline
Old 04-24-2011 | 03:45 PM
maybe it was bending the tie bar ...?
Old 04-24-2011 | 08:10 PM
GK's Avatar
GK
No problem with the tie rod but you need to closely inspect the clevis mounting brackets for hairline cracks. This is not a Nor-Tech issue, but it is an issue for the company that makes this component the tie rod mounts to. I just replaced both clevis brackets because of cracks. If one fails, it's deadly at high speed.
GK is offline
Old 04-25-2011 | 08:24 AM
Thanks GK
What are the Brackets worth ? did you go with the same manufactuer ?
Old 04-25-2011 | 07:23 PM
GK's Avatar
GK
My clevis brackets were from Imco which came with the Merc #6 drives new, it was a casting design flaw very common. They replaced the components at no charge with a new design. Imco was extremely accommodating, great company.
GK is offline
Old 04-26-2011 | 02:58 PM
Thanks again GK ..
Old 04-26-2011 | 04:27 PM
fountain4play's Avatar
On mine we used a large diameter tie-bar and extension towers on my Arneson's to make sure it was above the tunnel... I've heard on some applications that if the tie-bar is down too low the water pressure coming through the tunnel can bend it... From what I remember this was usually at or near the transition speed before the cat packed air at 70-80 mph or so...
Jim
fountain4play is offline
Old 04-26-2011 | 05:38 PM
Was the bar being to low a Nor tech problem or an issue on all boats with #6 .
Old 04-26-2011 | 06:32 PM
GK's Avatar
GK
Default Tie Bar
Per attached, tie bar hight with #6's is not an issues with the tunnel
GK is offline
