Renderings ...
#34
I`m never stuck with red, red vette, red head wife, red 3500, half red cig. work trucks red , red is the best color! .
The transom is still silver so it has to be incorporated into the paint job, that`s my only limitation.
New renditions today I hope.
RED!
#36
#37
We don`t have oil furnaces around here and Bosh I`ve never deal with either .
As long as your contractor knows the product and stand behind the warranty you should be fine.
Looks like they are using pro press fittings on the refrigerant lines but brazing near the heat pump.
Ive always wondered how a oring rubber seal holds up long term, I don`t think very well locally with the cold weather, we braze everything .
I use pro press on water with sucess but thats 45psi vs. 350psi .
i`m sure it`ll be fine .. if the contractor can afford pro press and the fittings they are most likely pretty good.
#40
In a Biden economy,
- Second home/Condo at LOTO.
- Upgrade and sold Cig
- Purchased another boat.
- New motors
- New interior
- New paint.
