Go Back  Offshoreonly.com > Owners Forum > Nordic
Mhale00 & Raylar Kit >
Old 10-09-2005 | 11:59 AM
  #71
LIOPA's Avatar
Default Re: Mhale00 & Raylar Kit
Originally Posted by bobl
At 80 MPH, I'm turning 5450 with a stock 30" Bravo 1, running an ITS and XR drive. This on glass smooth fresh water. My boat is an open bow, so I guess the slip could be higher because of this or maybe the salt water is a lot more dense?? I dunno....One thing I have discovered. I can turn about the same RPM whether the water is slick or choppy, but the speed can vary 4-5 MPH. So, it seems the HP is there but with really slick water the boat runs like the anchor is out. I've never experienced salt water with a nice chop in cool weather. My boat might run 100 under those conditions. Just more food for thought.
Bob
Makes sense.......the 32 Merc Lab was too much......resulted in a few MPH slower. The 28 Stock Bravo was not enough and kept tapping the rev limiter. We took that prop and added cupping. It is like a 29 or so. That got us the results above but we still have untapped RPM. He is trying a stock 30 Bravo like your set up on Monday. I will let you know what happens. BTW the boat hates calm flat water. It sticks(surface tension) to the surface and runs much slower. 1-3 foot chop seems ideal. Temps under 70 degrees help along with salt water which adds buoyancy, lift and better prop hook up (BITE) with less wash out / blow out/ slip.
LIOPA is offline
Old 10-09-2005 | 12:53 PM
  #72
Mhale00's Avatar
Never Enough
Ok. I had the boat out yesterday. The wind was blowing about 30 mph. but I had to get out and look for some flat water.
I took Rays advice and had a 1" spacer added. They also adjusted te fuel pressure. The Lowering the drive I think made the difference.Seems to be something heats would need to do. Very fast onto plane. Maybe 8 seconds. Oh yes, I had to fill the tanks as I was taking out 3 ladies and figured to be going quite aways up the lake. 4 people, 3/4 tanks, 1 cooler full. 30 mph wind. 3 ft chop in the basin, 6" chop in the narrows.
8 seconds to plane. fast out of the hole
69mph GPS @5100 rpms.
Friday in havazoo, Arron took it out on glass, 1/4 tanks 2 people, it ran 70 GPS @ 5100 rpm
I think I might see 72 in Just the right conditions.
I have to wonder what would happen to a stock 496 ho if you just add the 1" spacer?If you could pick up 3-4 mph by just doing that, It would be a hell of a lot cheaper than adding a raylar kit. I wanted to get back out today with just one other person and check speeds and time the mid range as well but the wind was blowing all night and is expected to be 40 mph at the lake. I will get out next weekend if not after work one day this week.
Mhale00 is offline
Old 10-09-2005 | 12:57 PM
  #73
Mhale00's Avatar
Never Enough
Now its time to detail it and sell, so I can order a 35 flame w/ 525's. Yes, it does seem like alot of work, just to turn around and sell it. But I wanted it for the summer, thats why I ordered it in April and expected it done by late may. So much for that plan!
Mhale00 is offline
Old 10-09-2005 | 01:13 PM
  #74
LIOPA's Avatar
I have a BURGUNDY one for sale here 2004......93.7 GPS.....Fully loaded
LIOPA is offline
Old 10-09-2005 | 01:27 PM
  #75
Indy's Avatar
Member #154
Correct, my Heat barely broke 60 in the dog days of summer when Long Island Sound was flat as glass. It did much better in the chop.
Poker Runs America did an in depth study of salt vs. fresh water performace a year or so ago and the result was NO DIFFERENCE. You might get more bite out of salt water, but it's denser and will cause the prop to spin slower, and yes the boat sits higher (fractionally) but it take a little bit more to push it. The opposite is true in fresh. It was an interesting study and the bottom line was that temp, humidity, and elevation play much more into performance than fresh/salt. If anybody is interested, I'll try to find the issue that the study was done, good reading and it debunked a big myth.
Indy is offline
Old 10-09-2005 | 01:33 PM
  #76
LIOPA's Avatar
Hey Steve....let me know what issue. Does sound interesting.
In the list you posted add wave/chop conditions also play a big part with stepped bottoms as well.
LIOPA is offline
Old 10-09-2005 | 02:56 PM
  #77
Linster's Avatar
Off the Radar
Never could figure out why the Heat does not run real fast. Nordic really hit the bulls eye on the Flame. That is the best acting boat I have seen with very good speed. I wish they would straighten out the Heat. There are a lot of people not wanting a twin but wanting a Fast single.
Linster is offline
Old 10-09-2005 | 03:11 PM
  #78
LIOPA's Avatar
TRUE linster........it is the mosty requested setup lately .... a fast 28-30 with a single 525 or ILMOR 625
LIOPA is offline
Old 10-10-2005 | 08:34 AM
  #79
Rage's Avatar
Originally Posted by Raylar
Mhale00
I assume you are the guy with the Nordic that I talked to a few weeks ago. First I have to interject that all hulls are different and some are not set up , x-height and such as well as they should be. Just adding a 100HP to any boat is no guaranty of 8-14 mph unless the drive heights, prop type and pitch and blade thickness are sometimes optomized to realize the horsepower addition. I understand that in talking to a few Nordic owners with your hull that adding a 1" drive spacer to your hull with the right prop has gotten them to be able to use the extra power and increase their speeds about 8-10mph with more power. Make sure you have a specific conversation with Aarron at Absolute about this item. The drive spacers are easy to add and apparently it corrects some x-height issues that have been plaging some Nordic hulls like you have. Raylar has had to many tests and confirmations of big power and speeds increases to know that our kits make 525HP. The problem sometimes like this is a hull that needs drive and prop tweaks to utilize the extra power of the motor.
After Aaron checks the boat and motor I will have him GPS test it on the lake and confirm his recorded speeds.
Some hulls, drives and props take a little more corrective action and tweaking , but a 100HP increase should net you more than 4 mph, I agree! I feel your hull running the right prop , drive ratio and x-height at normal weight should see about 1 mph for every 12HP which equates to 8mph and I think thats where you should be. Sorry our earlier production could not keep up with more timely shipping, we just got behind back in April. I also know Aaron got behind on the installs because he was buried with kit orders and other committments. We now have kits instock in good quantities and we ship all orders within two or three days after the dealer or buyer pays for the equipment. My apologies, no excuses we did our best, sorry for the inconvience and the trouble it caused you.
Best Regards,
Ray @ Raylar
Ray,
Any similar spacer or other recommendations for the Rage to improve hp transfer?
Thanks!
Rage is offline
Old 10-10-2005 | 09:55 AM
  #80
Steve Zuckerman's Avatar
Linster,
They will run, but typically not the way the factory sends them out. They are using a very high X-dimension for such a large single engine boat. This setup lacks the hydrodynamic lift needed to free it up with moderate horsepower, and it is still weight sensitive (placement and load) with horsepower. That's why some people are having success with drive spacers. It (high XD) does work better as the horsepower and speed goes up. I've worked pretty hard to get mine to 85. I used the Imco case to load the prop, and the P5-X to get enough blade area to lift the boat. The factory should make everyone aware of the P5-X prop. It does help the high X dimension issues (slow holeshot/high propeller slip #s) tremendously. The older padvee Heats ('99 and back) used a much deeper X-dimension that gave better all round performance.
On the other hand, it is a great looking, smooth riding boat with a spacious cabin, for it's size.
I think the step is just too conservative to be of much help freeing the boat up. If you look at the steps on the Flame, they are much taller.
Another small step on the Heat, or increasing the height of the existing step would help tremendously. My best friend's 29' Fountain has a single step in the same position (fore and aft) on the hull, but it's much deeper, like the Flame's. Just my 2 cents...............
Regards,
Steve
Steve Zuckerman is offline
