Newbie heat owner
I was running a consitant 61. I saw 63 once, but was never able to recreate that. With the procharger I'm running 71 - 74. With the higher HP does your stern ride higher at WOT than it used to?
Can't say I've noticed a difference. But I'm running an ITS with XR drive so the boat handles a little different than other 28's I've driven anyway. I actually think it's a little slower, but that could be just the XR drive. I never saw more than 61 when it was stock. It definitely needs all the bow lift it can get. I tried the hydromotive P5 and it had way too much stern lift and lost about 5 MPH. The P5X has much more bow lift. Seems like adding some cup to the tips helps on this hull too.
Originally Posted by LYNCH MOB
Hey steve do you think the x drive will handle 600+hp?
If it does break, then you can go ahead and rebuild it with the XR or other aftermarket (like Imco) internals and prop shaft.
Good luck.
Steve
It also accepts XR gears very easily. RV did this on our new one prior to us taking ownership. Of course RV did this because he lost an X gear at cruise on Lake Michigan
Take a peek here for some good info...
http://www.go-fast.com/mercruiser_bravo_sterndrives.htm
