Go Back  Offshoreonly.com > Owners Forum > Nordic
nordic heat projects >
Old 11-01-2005 | 06:20 PM
Steve Zuckerman's Avatar
Default Re: nordic heat projects
Originally Posted by Steve Zuckerman
Hi Guys:
Dave, I like your "recipie" for making more HP.
Speaking of making more horsepower. I just found the weak link, the XR drive. Probably my fault for not pulling it down after the last lube change. There was some peach fuzz on the lower magnet...........I figured it would make one last color cruise. I was wrong. I lost a tooth on the upper gearset, pushed the gears apart, etc, so I'm out a complete XR upper housing. The gearcase (we'll check IT ) seems OK.
Funny thing was, I was cruising about 45MPH ........
one of my Nordic friends who was riding with me said "you were going too slow". Oh well, rather now than March or April.
BobL, I am ordering another 1" spacer to test when we get her buttoned back up. I'll let you guys know how it goes.
I HOPE it works as well as yours.
Regards,
Steve
Well,
$4000 later, all the parts (new complete XR upper housing, small parts, and 1" spacer) are on the way. There goes the fun money (cam/kit & heads)! Easy come, easy go ..........F'ing Bravos .
Regards,
Steve
Steve Zuckerman is offline
Old 11-02-2005 | 04:49 AM
Linster's Avatar
Off the Radar
XR's biggest problem is the needle bearings installed in the gears. I replace mine every season. As they wear, the needles start shifting out of wack do to the extra clearance. It just a time factor at that point. They are cheap and realatively easy to replace.
They are many caged berings for the old Bravo gears that keep the needles verticle. AS of now, I do not know of any that will fit the XR gear.
Max Worx has one that was in my old drive, They cut out an addition .030 out of the gear and used a race that was also .030 less than the XR Race. They are pricey for those gears but they are worth the money if upgrading.
Good luck Steve.
Linster is offline
Old 11-02-2005 | 08:12 AM
Nordicflame's Avatar
Thumbs up Re: nordic heat projects
Steve,
After I scrambled an X drive on my previous Heat I bought a new XR from Bam and had Max go thru it before I ever put it on. They installed their caged gear bearings, tower race, caged clutch shaft bearing, seal carrier, torsional clutch shaft, top cap, etc and set up the clearances.
This was the 3rd year running 800-900+ hp with no issues.
It will be going back to Max this winter for a good maintenance service.
I'm sure the Redline HD Shockproof and a centrifugal SC helped quite a bit in making her live. Probably a bit lucky as well
Dave
Nordicflame is offline
Old 11-02-2005 | 08:19 AM
Good luck Steve.
Linster:
You are correct. I did not do enough preventative maintenance, and I'm paying for my lack of attention to this drive. Several of the drive experts that I've talked with this week while looking for replacement parts mentioned checking the clearances and reshimming annually, and that would extend the duty cycle of the drive. I like your bearing replacement idea too.
Something we used to do when I was racing outboards, was Magnaflux high stress parts, like shafts and gear sets. I sure wish I had done that on my upper gear set .........
Oh well, another expensive lesson learned. 750HP probably isn't helping a drive rated to 600HP either ................
Thanks,
Steve
Old 11-02-2005 | 10:06 AM
Originally Posted by Nordicflame
Steve,
Dave
Dave:
Wow, that IS some serious upgrading of the drive.
How much was this mod? I may consider doing that to mine as it's still "fresh".
Regards,
Steve
Old 11-02-2005 | 11:01 AM
Steve,
I have a fresh quote from Max to upgrade an XZ to MaxXR upper which would apply to your situation as well.
Includes...
Worx Billet HP Tower ($1100)
OEM XR Gear Set ($1395)
Worx Caged Bearings
OEM XR Tower Race
Worx Clutchshaft Bearing
Worx Billet Chromemoly Seal Oring Carrier
Worx 2" Billet top cap w/chromemoly tower 7/16 thread($449)
Worx Billet TrimBlock
Worx Torsional Clutch Shaft ($549)
Worx Billet EXT Coupler
OEM XR Gear Thrust Shim
Worx X-18 Upper Pinion Gear Shim Pack
Worx Billet 8620 Alloy X-18 Bearing Spacer
Worx Billet 8620 Alloy X-18 Thrust Washer
Worx Hi-Tork Uppper Pinion Nut
Worx Hi-Tork Upper Pinion Washer
Labor
$4505 total
Money well spent!!!
Dave
Old 11-02-2005 | 11:18 AM
Linster's Avatar
Off the Radar
Seemed like Max charged you as much as they did me. When I sent the check I thought I was crazy. After three seasons of a blower motor withoout issues it seemed worth it.
Linster is offline
Old 11-02-2005 | 11:48 AM
Kind of the "pay me now or pay me more later..." type of deal
Old 11-02-2005 | 12:03 PM
Steve,
Includes...
Worx Caged Bearings
OEM XR Tower Race
Labor
$4505 total
Money well spent!!!
Dave
Dave:
Thanks for the, gulp , #s, I think........even not needing the upper gears, that's still ANOTHER $3110, for a $6435 (total) XR upper....................
I'll have to sleep on this one!
Steve
Old 11-03-2005 | 01:06 PM
IndianaHeat's Avatar
Nothing on my Nordic but I'll be working two other Heats
A 500EFI Whipple install on my former Heat.
Then the fun one will be the addition of a R-Tech Supercooler setup on the Heat with my old motor. It currently runs a solid 95+ at Havasu so we'll be in search of the mighty triple digit
Also, if you didn't know, you can order the duplicate vinyl skins from Peggy at Nordic if you supply the VIN number. I did this with my rear seat last year. It was $150 and then $50 for the local shop to steam the foam and replace the cover. A perfect match. That back seat takes a beating
Dave
I Called nordic ..my 1998 heat has a different seat build up, he said they change in 2000. my sun pad is 8 " smaller. no skins for me but thanks for the info
IndianaHeat is offline
