Go Back  Offshoreonly.com > Owners Forum > Nordic
Measuring X dim on a Heat >
Old 06-01-2006 | 12:46 AM
Kokopelli's Avatar
Default Measuring X dim on a Heat
Has anyone figured out how to extrapolate the X-dimension from measuring from the bottom of the transom housing along the transom to the top of the notch? Seems like I read a thread about this a while ago. If anyone's got this let me know - mine measured 5 3/8". Thanks.
Kokopelli is offline
Old 06-01-2006 | 08:21 AM
Steve Zuckerman's Avatar
Default Re: Measuring X dim on a Heat
Kokopelli,
The actual X dimension is the vertical (not along the transom angle) distance between the drive shaft centerline and lowest point on the hull (on our boats, the pad).
On my boat this worked out to a rather high 19 1/4"s. This is why many of us are finding some extra efficiency (lower slip %/higher speed @ rpm) by using a 1" spacer and/or going to a 5 blade propeller.
As you have probably seen, many boats have a much deeper X dimension, and that's why Imco and others are selling all these 1, 2, and 3" short gearcases. In our case, it appears the factory has gone in the opposite direction direction, and on the late model step hulls gone too high with the X dimension. If you have a 2000+ step hull heat with a high X dimension, you definitely want to try a 1" spacer.
I have measured the X dimension on a pre step Heat (1999 back), and it was much deeper at 16 1/2"s, and these boats may (no one locally has done it, so I don't know) benefit from a short gear case.
Regards,
Steve
Steve Zuckerman is offline
Old 06-01-2006 | 08:27 AM
Nordicflame's Avatar
Koko,
I have a spread sheet somewhere and by the method your using it seems to me that all of the stepped Heats I have measurements for (about 10) they are all at 6-1/2 to 6-5/8 at that reading. I will check to be sure but it sounds as if your already down.
Dave
Nordicflame is offline
Old 06-01-2006 | 08:39 AM
Originally Posted by Nordicflame
Koko,
Dave
OK,
I found the spread sheet and the magic number is 6-7/8" which BTW is what I have for your buddy's new boat that used to belong to Rick Young.
I think this is the number where a spacer will do well.
I have some sea level numbers for that boat as well if you are intrested.
Let me know,
Dave
Old 06-01-2006 | 11:45 PM
Kokopelli's Avatar
Koko,
Dave
If thats the case I must have one of the few step bottoms with a lower X. What's the easiest way to measure when it is on the trailer?
Old 06-01-2006 | 11:49 PM
Kokopelli's Avatar
OK,
Let me know,
Dave
Yea let me know what the sea level numbers were. He's trying to decide what props to put on it for Powell and Flaming Gorge. Do you know if Rick swapped out the lower - the one that is on there seems to be newer than the upper and also has holes drilled in it for a different drive shower. The lower he has, has the dual water pick-up.
Old 06-02-2006 | 08:19 AM
Simply measure from the bottom of the transom housing to the top edge of the notch (lay a small straight edge along the surface of the notch for accuracy)
Just compare it with your buddy Pat's for comparison.
Dave
Old 06-02-2006 | 08:27 AM
I have no idea on the lower. Might want to call Rick.
He will want a 22 Bravo for Powell (maybe 24 if he plans on a lot of cruising with a light load) and a supercharger for the Gorge
Sacramento Delta
26 Bravo / 74 degrees/12" chop= 66mph at 4900
26 Bravo / 95 degrees/12" chop= 64mph at 4750
mikesufka
05-03-2007 09:30 PM
Blue by You
9
06-12-2006 02:59 PM
racer-x6
03-02-2005 09:16 AM
t500hps
14
12-19-2004 08:02 PM
dyno
23
06-13-2003 05:06 PM
