Finally Plugged the hole
Bent,
Nice move......your shins will thank you for it.
I got rid of mine too. The only thing I ever used the ski pole for was anchoring. Unfortunately, when I anchored off the transom, my rope would usually get tangled up in my drive and prop.
I put a transom light over mine.
Regards,
Steve
Regards,
Steve
Did you see the new ones they are putting on the Thors????They are like a Pop up Mushroom Cleat....I was hoping one of them would have worked on mine (NOT) the angel on the Thor is way different then the Heat
Correct on the Thor......I am trying to get Nordic to make that ski pole an option (On or Off) all models. No charge if you want one.
I KINDA LIKE THE POLE FOR PULLING MY FAT AZZ OUT OF THE WATER. THE KIDS USE IT TOO FOR THE SAME REASON. PLUS WHEN WE GO TUBING IT MAKES IT EASY FOR THE TOW ROPE. BUT IT IS A MUCH CLEANER/SLEEKER LOOK WITHOUT IT!
