Go Back  Offshoreonly.com > Owners Forum > Nordic
the initial #s are in >
Old 05-31-2007 | 11:04 AM
  #91
Originally Posted by Rage
Bob , was the 150hp increase just do to the JV head work or was there other mods as well that contributed?
I made a lot of changes so there's no way to really say what made the difference. I lowered the compression from 9.5 to 8.5, had a custom cam ground and of course the head work. I also ported the throttle body quite a bit. Before the throttle body mods it made just slightly more HP than before. So, it would appear the cam and head work offset the compression reduction. Then I was able to increase the boost to get back to where I was, compression wise.
bobl is offline
Old 05-31-2007 | 11:07 AM
  #92
Originally Posted by Steve Zuckerman
Bob,
Great #s for the conditions ! Sounds like there's plenty left. What prop were you running? See you at the Jamboree!
Regards,
Steve
That was with the 29 P5X. But, I didn't even look at the tach or do a data log. I know, sounds crazy but there was a lot of debris in the lake, so that's all I was watching for. Just made a short blast and looked at the GPS to see what it read afterwards. I should get some good numbers this week.
bobl is offline
Old 05-31-2007 | 12:13 PM
  #93
Anyone else notice that on all the pics of the gauges, it seems only the speedo is working? Weird...
jima97 is offline
Old 05-31-2007 | 12:33 PM
  #94
That's because it is a GPS speedo with recall. Just flip a switch and it shows the maximum speed you hit. A lot easier to take a picture of that than when you are running 90+MPH.
bobl is offline
Old 05-31-2007 | 01:14 PM
  #95
Talking
Read all of the posts. I called him out on that! I thought I busted him but he's smarter than me after all!
kennyo is offline
Old 05-31-2007 | 01:46 PM
  #96
Didn't know that...cool feature.
jima97 is offline
Old 05-31-2007 | 01:47 PM
  #97
thunderusone's Avatar
Only Appleton can run 127mph with his boat off......at half throttle.
thunderusone is offline
Old 05-31-2007 | 02:26 PM
  #98
Steve Zuckerman's Avatar
jima97,
Are you "up to speed now" ?
Steve
Steve Zuckerman is offline
Old 05-31-2007 | 02:46 PM
  #99
He's sandbagging.......it's actually 172......
Steve
Old 06-01-2007 | 09:43 AM
  #100
I did a little more testing yesterday and got some data. It ran 92.2 right at 6000 RPM with the 29 P5X. Smooth water, 90 degree temp, 2 people, full fuel. I think I'm going to order a 32 B1 and try it. I'd like to get the rpm to around 5800.
bobl is offline
