Calling Steve Zukerman
Steve,
What is the distance between the notch at the rear of your transom, and the prop centerline. Or keel to prop centerline. I want to determine what my 08 is set at in comparrison to your boat. My boat is coming with an IMCO Extreme SC outdrive, with a standard length IMCO lower leg. lI will not recieve my boat untill around the 18th of this month, but when I do, I will post this measurement on line.
Thanks,
Chris
Thanks,
Chris
Hi Chris,
I have measured mine 2 ways. One is the actual X dimension, which is 19.25"s. That is driveshaft centerline vertically to the bottom of the pad.
The easy measurement for comparison to mine is from the box at the bottom of the gimble housing where the trim lines come out, to the top of the notch, measured along the transom. Mine measures 6 3/4"s there.
I'll take a look at the measurement you are asking about. It's my understanding that some of the late 07s and all of the 08s are now 18.25"s, which I would consider perfect. Better late than never. Even though we have figured it out , this is something the factory should have done themselves years ago with research and testing. To give you an idea how bad it used to be, my boat GPS'ed 76 MPH when I bought it. I think you'll see better quality and rigging standards from the new management.
I am running a standard length Imco case with XR gears, and a 1" spacer (so our drives are hydrodynamically the same), making mine an effective 18.25"s, and the boat handles very well in all aspects, holeshot, midrange efficiency (never worried much about that one in the past, but $4 a gallon gas
), high speed handling, and rough water.
I do think the P5-x is a big help too. As the XD goes up, you have less blade area in the water, and that extra blade really helps carry the boat, and lower the slip %.
Regards,
Steve
), high speed handling, and rough water.I do think the P5-x is a big help too. As the XD goes up, you have less blade area in the water, and that extra blade really helps carry the boat, and lower the slip %.
Regards,
Steve
Steve,
Thankyou for the reply. I am looking forward to setting up my boat to run the most efficient possible within the first year while the motor is still in warantee. After that, I am planning on slowly doing mods to the motor untill it is "being all it can be" I would appreciate the prop depth mesurements relative to the notch or keel to determine prop depth of your boat. It is my understanding that you can change prop depth with different length lowers while keeping the measurements you mentioned the same. ie 18.25 or 19.25 inches from notch or keel, to driveline center, but changing the lower to suit prop depth.
I am also anxious to try a P5-X, as I have heard good things about it. Who do you have them tuned by?? It is my understanding that Throttle-Up is no longer working with Hydromotive.
Thanks again,
Chris
P.S. Sorry about the misspelling of your name in the heading on this post
Thanks again,
Chris
Hi Chris,
You are correct. Not only is Throttle Up not selling Hydromotives any more, they aren't modifying anyone else's propellers. It's a shame because they did great work.
You can buy them directly from Hydromotive, and they have an exchange program, which will allow you to find the correct pitch. I am probably going to sell my 28" TU labbed P-5X, and run a 29", if anyone can use the 28".
They also do their own lab work, once you determine the correct pitch.
Regards,
Steve
Regards,
Steve
Spoke with Julie yesterday (Very Nice to talk with) TH will be manufacturing something comparable to the P5-X in the near future. Possible by March. Might be worth the wait. It will be a CNC prop and a bit more expensive than the Hydromotive.
.BTW, Hydromotive came out with a 4 blade version of the P5-X, called the Quad IV-X. Looks great and ran very well on a friend's twin engine Fountain with high XD. Maybe worth a try.
Precision Propellers (anyone remember the Turbo?) has come out with a new 5 blade. I will try to test both soon.
Regards,
Steve
Chris,
I just referenced another thread where Southocg and I were comparing XDs. If our cross references are correct, my propshaft (with a 1" spacer and standard length Imco case) is 4.5" below the pad. I haven't actually measured it, but that should be very close.
Regards,
Steve
Regards,
Steve
