Hey Plane Silly
#31
I am holding off on the transom pickup until I do some more testing. Bob L recommended that I block off the 4 upper holes on the outdrive and see if that helps my press some. The weather has been crap here so it looks like another weed before I can get her in the water. I would still love to see a pic of a transom pickup on a Rage.
#34
Well, I took a water press reading at the raw water pump right where the sensor is and it sure seems low. At 50 mph it was only about 10 psi, at 80+ it did get to around 22 psi. Motor still runs around 170* even though I have a 120* thermostat. And yes I have replaced the thermostat and tested it in hot water. Still seems like I have a flow issue.
#35
What rpm's are you getting the 10 psi and the 22 psi at?
#37
With the recent addition of a 5/8" dia sea water dump hose 'T'd' into the out let side of the oil cooler water hose (to increase cooling water flow rate through the oil cooler) the sea water pressure dropped to 15 psi @ 3500 rpm and 30 psi @ 5000 rpm and 1.5-2 psi @ idle.. Sounds like yours is low for the 496HO. My coolant still stays in the 140F's during WOT running even with the addition of the water dump hose.
How many hours/seasons on your sea water pump/impeller? Ever get into sandy/muddy water with the lower unit? I understand that the stock brass body water pump can get chewed up pretty quick if sandy water runs through it.
#38
I have rebuilt my sea pump with the stainless plate and new impeller so it should be good. I have a big event at Cumberland this week so I may just leave things alone right now but it is looking more and more like I am going to have to install the transom water pick up.
#39
I probably mentioned it before but I have been warned by one very experienced person that steped hulls (Heat) can have aireation problems with transum water pick ups that also result in cooling problems. Hopefully someone out there has a proven successful transum pick up mounting location for a Rage. Good luck and keep us posted.
