Go Back  Offshoreonly.com > Owners Forum > Nordic
06 Heat set-up questions >
Old 04-12-2010 | 04:29 PM
Default 06 Heat set-up questions
Well I finally jumped on the Nordic bandwagon. The wife and I bought an 06 Heat open bow. The boat is out of the AZ, Ca, area and likely set up to run that altitude. We are a little higher in Utah at about 4500 ft. Any set-up suggestions on prop etc. Also been seeing a lot of chat on x dimensions etc. Do I need to address anything there. Boat has the 496 ho w/ Bravo x. Thanks
chase8 is offline
Old 04-13-2010 | 02:17 PM
Default welcome
Welcome.
What lake do you boat on in Utah?
What prop does the boat have on it now?
What gear ratio is the outdrive?
oboyskibum is offline
Old 04-13-2010 | 05:57 PM
Congrats, welcome! Like to see more of us up in the frozen mountains (enough already).
Try what you got & get some #'s with a GPS and the tach. Go down a size for every 300 rpm you need to gain. So if your at a 28 turning 4200, go down to a 24. That get's you to 4800. Then lab it & you should be money.
I would HIGHLY recommend Merc lab it. They can get it on the nuts if your #'s are accurate.
90mphRAGE is offline
Old 04-13-2010 | 06:21 PM
At that altitude you may need to re-gear the drive to 1.65:1. That boat would normally run a 24" Bravo 1 at sea level, 26" if it were a really good running boat. Run it with a 24 and see what it does. My guess is you won't get near the rpm you need, which is at least 4800.
Bob
bobl is offline
Old 04-14-2010 | 11:15 AM
Nordicflame's Avatar
22 or labbed 24 here in our area with optimum rpm 4900-5000.
I've tweaked 2 Heat HO setups here at our altitude and that's where we ended up at.
You can get away with a stock 24 at the less than 4400 feet lakes such as Powell, Utah Lake, Willard etc. but Deer Creek, Gorge, Bear and any of the 5500+ lakes you will need the 22 or lab 24.
One I just added a little helper to (3.3L Whipple, cam, head work, etc...) and it's back with a 28@~5300 or P5-X 27@~5300)
One inch spacer helped a bunch here but it was an 05; Not sure if they changed anything in 06...
Dave
Nordicflame is offline
Old 04-14-2010 | 01:17 PM
Good info! Thanks I really appreciate it. We will be up at Pineview
quite a bit when the winter finally loses it's grasp, hope to see some of you.
chase8 is offline
Old 04-14-2010 | 02:38 PM
Hopefully summer comes quick now that snowbasin is closing up shop soon. I am sure we will see you at pineview.
Old 04-14-2010 | 02:42 PM
Might have our own Nordic Regatta
Old 04-14-2010 | 02:44 PM
Ya look us up, If ya do Rum n Coke I'll mix you a beverage.
chase8 is offline
Old 04-14-2010 | 02:55 PM
I like the idea of a local regatta. Pineview isn't the closest for me, but what's a few more gallons of petrol if there's free rum & coke!
