-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   Dana manifolds (https://www.offshoreonly.com/forums/nordic/248805-dana-manifolds.html)
dieselpup 03-04-2011 08:16 PM
Dana manifolds
Hello, new on here, and have a question about some manifolds for a 97 scandia, 454 carbed mag. The engine is completely stock, and I just want a little more noise, for now. I think I am leaning towards the Dana manifolds, but not sure which ones, since it has the s pipes for under swimstep. Would just like to know which set would be best, and be an easy bolt on. Wondering if the long risers would work? I think I was looking at a vortex bravo #4 system. Since I would like to add more power someday, and the shorties talk about reversion. Thanks...
blownhammer2000 03-04-2011 09:41 PM
dana marine is a very good choice, most don't realize they are more of a tube header design than a manifold style and perform very well, i've personally had them on a 7.4 310hp and was able to spin a taller prop as my rpms went up from the swap, install was fairly easy and they include the oil filter relo, hardest part for me was getting those dam cast iron manifolds off :angry-smiley-038: i would think you would need the short riser to work with your s pipes, but not 100% on that
p.s. welcome to OSO!
Uncle Dave 03-04-2011 09:52 PM
If you are going to add power someday put the longer risers in now on anybodies header. That way you do it once.
Dana's a good choice. Their header is gaining popularity fast.
You have a few choices though.
Heres the order I would go in.
1. Imco Powerflow plus
2. 3 way tie - Dana/Stainless Marine/Eickert
3. Eddie Marine
4. Gil
5. Stock replacement.
I hear revolution makes a nice piece and trust the guys that report on them.
East Coasters will pimp the Stainless Marine Gen 3's which are excellent but dont have the secondary runner length the Imco does.
Uncle Dave
dieselpup 03-06-2011 03:13 PM
Thanks guys. Was out looking at exhaust today, and don't have much room with those s pipes. They are squeezed in there pretty tight, not much room to work with. Thinking if I do just leave engine stock, would some short risers be ok? It's the 350 horse 454 mag. I just want it to sound better. Or am I wasting time? Don't beat me up too bad. Haha..
Uncle Dave 03-06-2011 03:15 PM
even shorties will help you out vs stock.
Exhaust is the foundation by which the rest of an engine build stands on.
UD
dieselpup 03-06-2011 03:23 PM
Ok, thanks. Those merc manifolds are pretty crude, aren't they?
blownhammer2000 03-06-2011 07:52 PM
one word, YES! the dana's def enhance the sound for sure, and look 10 times better
nedpoole 04-07-2011 12:28 PM
you should have plenty of room to do the turn down risers... plus, if it's extra noise you're looking for, the turndowns are louder than the standard short risers since they keep the exhaust dry till the bottom of the turndown.
here's a pic of mine on my 2000 heat. if your exhaust comes out on the driveshaft center line, it should be the same as mine
http://farm5.static.flickr.com/4076/...bbba104d_b.jpg
http://farm5.static.flickr.com/4137/...079fd283_b.jpg
http://farm5.static.flickr.com/4140/...fe1718b5_b.jpg
CumberlandHeat 04-07-2011 10:53 PM
The Dana exhaust is being installed on my 496 HO as we speak! I will let you know how it turns out.....
dieselpup 04-08-2011 01:51 PM
Thanks 05r1. That is the same set I ended up ordering, just kind of patiently waiting on them to show. Nice set up you have there. Were you able to use stock s pipes, and just cut them in half?
