Poor performance
They used my ignition system to do the dyno test.
They started the dyno test at 3000 528 tq 301 hp
I have a 26p bravo prop 4 blade.
I believe my check balls are still in, I will see and pull them if need be.
Wish I had access to a variety of props, but I don't.
I really appreciate everyones input and will try each and every possiblility.
Timing was rechecked just prior to putting it in the water, Yes It does have a timing tab mounted on the frt cover. I also checked the TDC against the dampner when assembling the motor and it was dead on.
Well everyone, I checked for air bubbles in the suction side of the fuel system, none, also have 0" vacuum on the gauge I attached. Do have 7-8 psi fuel pressure at the carb fuel pressure side. Replaced the distributor also with one that has weights, set the timimg at 8* and checked the advance, went to 38* at 2500rpm. Checked all the plug wires and replaced the spark plugs with new onesand gapped them at .050.
Now I have a popping through the carb off idle when throttling up hard.
Maybe a power valve? Did you have a backfire?
UD
