actually the piston change was done just before i bought the boat , the previous owner was gung ho to have a beast of a motor and a 100 mph boat which it is(so not sure what the exact reason was that he decided to change the pistons) .. however even pumping out that power the boat idles great and has run like a top all summer !!!!!! the mid range is unbelievable i just want something bigger for the boating i want to do ill see if i can post a couple pics
not sure how to post pics?
Do you have a host such as photobucket that you use? If so, just copy the [img] url into your post and it will show up.
nope sorry dont have a host service
Then I cant tell you anything that will help. If you want me to post em up you can email them to me. [email protected]
will do many thanks jay
Here you go!! These are jimmyg's heat BTW.
http://img.photobucket.com/albums/v4...0709-00016.jpg http://img.photobucket.com/albums/v4...40/38577_8.jpg http://img.photobucket.com/albums/v4...40/38577_4.jpg http://img.photobucket.com/albums/v4...40/38577_2.jpg http://img.photobucket.com/albums/v4...40/38577_1.jpg |
thanks jay !
Hey there with the 08 heat good looking boat! I noticed that the exhaust is going out the back instead of the corners, is that the only way to make it work with a 600SCI engine in the heats? Also do you have to cut out the engine hatch to make it work with the supercharger?
no cuts made to the engine hatch .. previous owner had the routed that way as he told me it was way to loud for his liking after he had the 600 dropped in
| All times are GMT -5. The time now is 09:49 AM. |
