New 2005 Rage!
holy sh*t its my twin!?!?!
the only difference is mine is grey where yours is black, it is a badass colorscheme, i thought at first it was alittle too much for me but after i kept looking at pics and then it showed up i changed my mind very quick, quick footnote, the trailer is the base color white for all colors, you will realize how quick that white shows ALL the chips, good luck with it!
the only difference is mine is grey where yours is black, it is a badass colorscheme, i thought at first it was alittle too much for me but after i kept looking at pics and then it showed up i changed my mind very quick, quick footnote, the trailer is the base color white for all colors, you will realize how quick that white shows ALL the chips, good luck with it!Did you mean "Blue" (not black) for the pattern or where you talking about the black parts around the main pattern?
i saw yours on powerboatlistings, mine has the grey accents in the interior and on the edge of the flames, also the NORDIC on the swimplatform is grey, other than that they seem to be identical, i've seen some others that are close but not exact, subtle changes here and there, i didn't think nordic duplicated gel designs exactly
Do you have the factory sound system in yours or did you upgrade? Trying to figure out the best way to upgrade my system now.
still factory for now, haven't figured out what i want, i'd sooner hear the 496 rather than music and it gets me by while rafted up somewhere, thought about two 10's in the rear bench but i'm not big on free air subs and nordic utilizes the space so well its hard to place a box anywhere, and i do not want the amps in the engine compartment, i am VERY picky and won't do it unless i have it 100% planned out and looking like a factory install on paper
Did you see my other thread where, I think it was 05Heat, posted up a set of pics where he installed 2 12" subs in the back bench. He replaced the bench with the box essentially, and it looked pretty darn good. That is what I plan on doing as well. Amps...not sure yet. I am running large amps and dont know where to put em yet. Good luck with all that
Yep, I saw the heat, he made a really good job of that. Lot of work though and I'm not sure I like the idea of chopping up my new boat. My biggest thing is speakers. I think I need some just at the back of the cabin somewhere so they can be heard when running (like the guy in one of the threads I saw that put them just in front of the fuel tank fills on the Heat). Not enough room there on the Rage though. Still looking for a good spot. On the amps; the best place (and easiest) on my boat I think is behind where the cooler sits (that's where the satellite box sits now). Away from the hot engine and out of site most of the time, but easy to get to when needed.
