Stern Light ??????
Ok, the stripper pole stern light goes up and down but the light won't light up, it looks like a LED light, is there a way to test the light? also at what point does it light up, when the pole is all the way up or when it starts going up?
If its the same motorized one as mine its innovative lighting or something like that...it lights as soon as it starts going up.
http://www.diamondperformanceparts.com is where I got mine. Give them a call they should be able to get the led bulp part. |
I just had to replace mine because the mast was damaged.
http://www.innovativelight.com/ Thats who makes the light (they dont make the power mast anymore). |
That light is a piece of crap. Replaced mine 3 times already. I now have a manual on order. Should be here any day, From Eddie Marine $120.
Please let me know how it looks and also how the install goes? Thanks
Just got it today. Looks exactly the same as the power light. Direct replacement.
simple install. you may need to remove the panel in the engine compartment for easier access. The new light is a 2 wire connection, the old was 3 wires. boat harness wiring / to new light wiring: boat harness green / to new light red boat harness black / to new light black red to old light blue (not used anymore) its the constant feed 12v |
| All times are GMT -5. The time now is 05:47 PM. |
