steering wheel center cap removal '04 Heat
Subscribe
11-27-2018 | 05:28 PM
I'm trying to remove the factory center cap without damaging it. I can get a razor blade to go into the joint between the cap and the wheel in a few spots. I can't get it to budge. How is it held on? I don't see any set screws or other exterior means it's held together.
Thanks guys.
Reply 0
11-29-2018 | 06:32 AM
It is glued in pick up a set of soft pry tools they are nylon they wont damage aluminum they are wedge like tools can probably get a set from harbor freight or similar. Take soft pry and a hammer where you have been putting blade and tap away once you get pry tool in there you should have a gap then just work your way around with another soft pry hope this makes sense and helps you
Reply 0
11-29-2018 | 09:49 AM
Thank you so much! I will try that.
Reply 0
02-25-2019 | 02:37 PM
After I pulled the steering wheel center cap. I threaded the back and used it in place or the tow pole. I never towed anything and it seemed to be in the way all the time.
Reply 0
