Prop help Best Prop for a 28 heat
#61
Originally Posted by bobl
The stepped version of that hull would come with a 26 with the 500. I'd try the 24 and see where you're at. The 26 may be a bit too large. What engine, speed and prop were you getting before?
58- 61 mph at 4800- 5000 Rpms weight 5800#- 5400# depending on water and air temps.
#62
I think the cupped 24 is the correct prop for your boat. My calculations put your speed around 66-67 with the HP500 so I think you'd spin that 24 around 5100-5200 RPM.
#64
I'm in the market for a boat around 28'. I recently inquired about a 2003 heat with a stock 496HO and the salesman told me it sees mid 80's. I assume this man is on crack?
#67
Guys,
Ran today with the 28" P5-X, this time loaded heavy, both tanks topped off. The boat ran 84 @ 5500. I'm grinning
This was just a quick 1/4 mile blast. Very efficient in the midrange, 50 MPH @ 3500. These props are the sh*t on these boats.
Tomorrow I'm trying an Imco gearcase in the same gear ratio to see what that does.
Oh yeah, the pressure valve worked great with the intercooler. I'm very happy with the plumbing setup now.
I set it to kick in @ 8 PSI. Nothing at idle, gushing as the boat planes off.
Regards,
Steve
.This was just a quick 1/4 mile blast. Very efficient in the midrange, 50 MPH @ 3500. These props are the sh*t on these boats.
Regards,
Steve
#69
Guys,
I ran the Imco lower unit today. Same ratio (1.50), same height (standard) gearcase, with the same 28" P5-X.
Objective results VS the XR, you heard it here 1st
85 MPH @ 5600.
Net results are:
1 Gained 1 MPH
2 Gained 100 RPM
The boat was loaded (light on gear, 2 nearly full tanks, 1 person) exactly the same as yesterday. Test conditions were close to identical (60o air/50o water/moderate chop).
Is the Imco worth $2100 for a case, switching your internals for just 1 MPH? Tough call. Not too cost effective.
Upside though, I did hit the limiter, so there may be more there, It looks cool as hell, my water pressure was 10 PSI higher @ 28 PSI (better for the motor and intercooler).
Oh yeah, the boat did handle very well, maybe just a little better.
Regards,
Steve
PS Century 29, tell your dealer he is dead nuts on for speed, he's just 300 HP short.
,85 MPH @ 5600.
Net results are:
1 Gained 1 MPH
2 Gained 100 RPM
Regards,
Steve
MIKEHTMSR24
07-22-2002 03:18 PM
About 800hp will get you there
