-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   500 EFI Power Increase (https://www.offshoreonly.com/forums/nordic/94901-500-efi-power-increase.html)
Strip Poker 388 05-14-2005 06:04 PM
Re: 500 EFI Power Increase
I would run it higher but thats me :D
Iam trying it out Sunday . got to get some base line speed before I start changing props.
Rob :drink:
39 Unlimited 05-15-2005 08:04 AM
Originally Posted by lotti
don't think I'll need whipples, remember my motors are stock tired 500's not freshly worked 500's with higher comp., worked heads, and cam. Or maybe I just can't drive the boat yet second time out :evilb: :evilb:
Lotti, your boat should run 86 - 88 GPS stock and unless your motors have an excess of 400 hours on them they're not tired.
The 35 loves trim, run your trim out to 61/2 - 7 and tab down slightly north of level. If you have a digital GPS you can test your setting by watching the GPS as you adjust. As Linnie found out the boat speed will increase with some tab. I always run the front (center) gas tank full and side tanks empty as this too seems to help weigh balance.
Good luck, when your ready for a new 04 0r 05 I'm your man.
Nordic Gary
Nordicflame 05-15-2005 10:28 AM
Linnie,
If you have a print out of the numbers, try finding your absolute peak torque rpm and prop for 1250 rpm above that. This will unload the prop torque and should generate the best overall speed. It's hard to tell on the graph :cool:
Gary,
A little tab for speed? Is there a tab number setting? I'm headed out right now and will give that a try. In my eperienced 2 hours of time :p I haven't even hit the tab switch :D
Going to take some time I suppose.
Another interesting find, we pulled the turbulators out on my friends Rage with 496HO and picked up about 150 rpm. I drove that boat for 30 minutes at 60-70 mph pulling him behind it. He's practicing for this years Catalina where next year may be the Flame will be doing the work :drink:
Strip Poker 388 05-15-2005 10:44 AM
[QUOTE=Nordicflame]Linnie,
Gary,
QUOTE]
I am running mine way above the 1250 above peek TQ
39 Unlimited 05-15-2005 04:07 PM
Originally Posted by Nordicflame
Linnie,
Gary,
I run the tabs at 4 - 41/2 and trim at 7. The tab completely elminates the chine walk as well.
39 Unlimited 05-15-2005 04:08 PM
Linnie,
Gary,
I run the tabs at 4 - 41/2 and trim at 7. The tab completely eliminates the chine walk as well.
Nordicflame 05-16-2005 08:20 AM
[QUOTE=Strip Poker 388]
Linnie,
Gary,
QUOTE]
This was found to produce the best speed numbers after "extensive" testing by Hydromotive and ThrottleUp propellers. There may be exceptions to the rule I suppose.
It looks like from the graph that Linnie peaks around 4200 so with that formula 5450 sounds about right.
Strip Poker 388 05-16-2005 08:31 AM
Gary on my Dyno sheet the peekTQ was with in 9 ftpds from 3900-4400 and the HP was still climbing at 6200rpm.So far I have ran it up to 6000. I wonder if I prop it up some if the speed will pick up .But its still making power at 6200?
Rob
Nordicflame 05-16-2005 08:42 AM
Rob,
It may be worth a call to Hydro or Julie at ThrottleUp. They are very good at sharing their info and they certainly have a long list of case histories.
I'm thinking it might have to do with where the torque may be falling off. Just a guess though.
Dave
Linster 05-16-2005 10:10 AM
Rob
Rob, I would not be spinning it that high. The life of the the valve train will suffer. I would look at spinnnig it 5600-5800 for the best speed and life.
Even though the dyno sheet shows it still making hp, once the torque starts falling off the the engine can not shove the boat through the water anymore. The faster you go, the more drag you have, and the more Torque you need.
What props and gears do you have in those BMAx?
