-   Nordic (https://www.offshoreonly.com/forums/nordic-99/)
-   -   35' Drain plug in front step (https://www.offshoreonly.com/forums/nordic/99982-35-drain-plug-front-step.html)
Linster 04-05-2005 07:12 PM
I was over looking at a buddy of mines 2001 flame today. He is getting the bottom redone. He had a drian plug in the front step. Mine does not, 2000. Did they start that in 2001? Makes sense to be able to get the water out.
t500hps 04-05-2005 09:57 PM
Re: 35' Drain plug in front step
Linnie,
I will need to re-do the botom of my Formula at somepoint? What is he having done.....and now back to your regularly scheduled question from above. :D
Linster 04-06-2005 04:37 AM
Russ,
The boat is at Progressive ( Joe's ) shop. They are filling in all the nicks and scratches. It is hanging in the air and they are filing in the holes with gel coat. They are going to start sanding to get it smooth. Joe tells me they then take wool buffing pads on a grinder, load the wool pad up with bar wax until its full. They buff up, down , right, left in a small spot to bring it to a as new luster. He says the gel gets so hot, it would feel like a burn on the skin if you touched it. I saw Mike's boat when they finished, it looked new,
Good Luck tonight, I will be hanging at the office after work. I need to flush out the engines well from the trip last week.
rv 04-06-2005 07:28 AM
2002 has the drain plug.
Rick
BajaIceBreaker 04-06-2005 09:02 AM
What would a "resurfacing" job like that cost?
39 Unlimited 04-06-2005 11:45 AM
Water does get trapped in front of the bulk head, would be good idea to add this plug. Chances are there is some water holding.
Linster 04-06-2005 01:49 PM
$2500 to $3200 depending on how bad.
I will do.
Dean Ferry 04-06-2005 02:54 PM
How does one go about installing said drain plug?
Dean
excursion 04-06-2005 05:00 PM
Drill hole on the bottom area on front step, seal new drain plug assy. silicone 5200 and insert & screw down and your preety much done.
