-   Northeast US (https://www.offshoreonly.com/forums/northeast-us-222/)
-   -   This is for 1CE and the Fall River Poker Run (https://www.offshoreonly.com/forums/northeast-us/172389-1ce-fall-river-poker-run.html)
marinetrans 11-29-2007 09:00 PM
Originally Posted by mikes280 (Post 2353192)
i guess everyone has a different idea on water pri. my motor makes 1078hp at 6200 i have 4 years on it at 10 lbs of water pri. run 4 or 5 poker runs a year never had a problem. i like to see a lot of water moving through the motor not always a lot of pri.my heads are the 357 afr's 540 inch motor 3.3 whipple. also i was in a gtx with 1075 merc's and they don't run that much pri.
Nice HP brother!! at 6200 rpm your probably making tons of volume and bronze valve guides help out big time.We found,in our cases,under 10-12lbs,made big problems for valves.Average hours were 2 to 3 before turning into shizzle. 20-25 psi is Merc's spec for psi, they sent a service bulletin on this.To be safe we make sure about water psi, under 20 psi we address water pickup issues,over 30 psi we install Merc's water bypass valve.
1CE 11-30-2007 12:01 AM
Volume
Originally Posted by marinetrans (Post 2350919)
It probably runs run on the hose,but top end you'll have no volume of water.A transom pickup is a must.I seen dudes hange valves because of not enough volume.Lack of volume seems to leave steam pockets in the motor,mostly in the heads around the exhaust valve guides.You'll need 1" thru hull and water pessure must be 20-25psi at WOT.
Peter, What's up ? ya Merc, likes 20-25 lbs But like u-said volume and flow is of ut-most importance @ higher rpms. see u-this summer J :cool-smiley-011: ps u-online ?
KNOT-RIGHT 12-01-2007 06:55 PM
Its about time ya renewed your membership:evilb:
When are you and Dave comming by the dealership
to drink all my beer and do burnouts with all the cars?
marinetrans 12-01-2007 08:08 PM
This week we're coming,lock up all the good booze.
slboatdrinks 12-01-2007 08:11 PM
Hey Pete,
When's the winter chill-out at your new house for all the northeast OSO'ers? :D:drink:
marinetrans 12-02-2007 09:13 AM
Haven't been online all summer, too much going on. Steve, I'm ready to party and fall off a bar stool.
Sick Stinger 12-02-2007 02:22 PM
Ill see all of you out on the water
