Winnipesaukee noise restrictions?
How do they measure noise restrictions? What decibal level does a boat nead to be under. If I remember corectly bolt on mufflers are illegal is that correct? Do you think a boat with twin stock 454 Mag's (385hp) would be louder than the decibal aloud.
I was checked a couple of times a few years ago (had stock HP500s with regular exhaust). The first time I failed (84db). 2nd time, I stuffed steel wool in the baffles. Had to do 3 passes with the average 82DB. First was 78, second 81 and third was 83 (as the steel wool disintegrated). They never caught on, and I passed.
The way the process goes, an MP can stop you and based on his / her judgment, can order a DB check. They make you make 3 full power passes at a very close distance (20 - 25') to the MP boat and put 1 MP on your boat. More of a PITA than anything else except that you can't use your boat until you pass.
Wow, that's crazy. On Lake George, NY they put the decible checker 1 meter from your transom at idle. The limit is 90. My 96 Scarab with 330 HP 7.4 rang up a 95.1. The AT is in the 99 range with my 525 EFI. Got tickets both times.
The did this off Timber Island which required almost a 90 degree turn at the end of the run to avoid a jetty. On one run, I got really PO'd and cranked the thing so hard, the MP almost flew out of the boat
Don't know if they changed the procedure, but it was ridiculous, unnecessary and dangerous.
