Go Back  Offshoreonly.com > Boating by Region > Northeast US
Snow Falling Time For A Winter Project >
Old 12-20-2011 | 04:30 PM
  #211
bigger they are the more power they make "mild" sooo 706's with big chief heads and 14-71's might push moby to 90 and last 60 hours lol
Unlimited jd is offline
Old 12-20-2011 | 04:33 PM
  #212
A 1075 merc is prolly the highest maintenance sub 1100hp motor out there compared to other builders motors with the same hp
302Sport is offline
Old 12-20-2011 | 04:34 PM
  #213
WildThing47's Avatar
You'll be lucky to get 30hrs out of a set of valves...custom pushrods....12* heads...haha....until the drives look at you after you put 1200torque through them going "i'm outta here prick"
There's a reason Merlin(WP) doesn't make the super-tall decks anymore...
WildThing47 is offline
Old 12-20-2011 | 04:37 PM
  #214
+1
The problem is the solid lifters.why they put a race valve setup in that motor is moronic....they shift, they run great, except the maintenance....converting to hydraulic...but that's why the new QOHC make everything obsolete...
Old 12-20-2011 | 04:44 PM
  #215
i'd put them in gear and they'd puke off the transom !!lol
Old 12-20-2011 | 05:11 PM
  #216
SS930's Avatar
As mentioned Frank, it's the valve train in the 1075's that make them such a maintenance nightmare. While mine have similar components, I have a lighter double spring setup that runs lighter seat pressures, so I can get away with a little longer time between top end tear downs. At the end of the day it's always a crap shoot when you're going to spit a lifter, spring, valve, etc with mechanical lift cams, so you never know. It's a lot cheaped to do preventative top end tear downs to be safe. I'm going to do my top ends before the boat goes back in the water...
The bottom ends can last hundreds of hours, or go 10... It all depends on your parts, how well they were put together, and how they are maintained/treated. Obviously the more power they make (not how much they are cabable of making) can be a huge determining factor of have long the bottom ends will last. A bottom end that's capable of handling 1200 but never sees any boost or high RPMs could last a lot longer than a lower output engine that's constantly at 5000+ RPMs and getting hammered... So there are a lot of factors in how long engines will go between complete rebuilds.
Btw, yours were built by a decent builder and babied for a lot of years, so its no suprise they lived to see so many hours.
SS930 is offline
Old 12-20-2011 | 05:14 PM
  #217
very well put, build it to handle 1200 and run it at 800 or my case build it for 650 and run at 475 lol
Old 12-20-2011 | 05:47 PM
  #218
Power doesn't kill motors, revs do...
Old 12-20-2011 | 05:54 PM
  #219
Lil red, ill trade you my boat for her straight up...
302Sport is offline
Old 12-20-2011 | 05:56 PM
  #220
302: I was offering the avatar guy, and a ride in the Outerlimits for her straight up..I figured red might like it now that he's just the "Cigarette" bandits hahah
