-   Ocean Express (https://www.offshoreonly.com/forums/ocean-express-74/)
-   -   Rigging information 25 OE (https://www.offshoreonly.com/forums/ocean-express/334894-rigging-information-25-oe.html)
scottymack 02-25-2016 01:00 PM
I have tried to get some information on my 1999 25 OE. The transom is all new with NO holes drilled for mounts. Does anyone have the knowledge on where to drill the holes?
All I need to know is:
Where to measure from to get center line for each mount and how high should the propshaft be above or below the transom? It is a 2 step hull.
20" merc 250 hp with sport masters and Bob's jack plates if I need them?
Thank you very much for your time, Scott
bulletbob 02-25-2016 05:12 PM
PM Jolley on this site he has a 25 OE with outboards and I'm sure he would offer to help.
scottymack 02-25-2016 05:18 PM
Hi Bob,
I tried to PM him and his "box" was full. I emailed Ross last week but no answer yet. I also called Sparky @ Vicious Marine and left a voicemail. I figured between all of these people I should be able to get accurate info. I only want to drill ONCE!!! lol
Jolley 02-25-2016 05:19 PM
Scotty, Just cleaned out my pm's .... I can send pics, etc. You will like the boat.
May need a tunnel tab for where the X is at...Let me know what you may need...................
scottymack 02-25-2016 06:05 PM
Thank you in ADVANCE!!! i just need to know where to get the centerlines for the engine mount so i can drill the holes. It is a 99 with 2 steps. should i use the jack plates or mount directly to the hull?
scottymack 02-27-2016 10:17 AM
hi Jolly,
Were you able to find out any information for me? Tks,Scott
scottymack 03-07-2016 05:55 PM
Thank you for the help. Sparky from Vicious called me and gave me all the information I need. He did say something to me that I thought about after I hung up. Is the 1999, 2 step model longer than 25 feet? I thought I heard him say 28"?????
Jolley 03-08-2016 06:31 AM
That's great Scott, Phil knows these boats and their rigging. There is a thread from long ago about my tunnel tab build . It really flattened the boat out, take a look for it.
There isn't a lot of info on the O/E's but they are bigger than they measure as far as OAL 'over all length' There was a time when the boats were measured at the water line, as that was all you needed for registration was what you displaced in the water. Best of luck. Snow's finally melting so I can take a look at mine and get ready for the season. Bill
scottymack 04-01-2016 06:49 PM
hi Bill,
would you any pictures of the inside transom area? The previous owner removed some bulkhead? knees, or other supports before the transom was replaced.
they never were put back in. Also it would show me where the batteries go and some other rigging, TKS!!!
